Go Back   Home > Forums > Source & Line > Digital Line Level
Old 1st September 2010, 07:06 AM   #11
audi0 is offline audi0  Australia
audi0's Avatar
Sweet!
Old 23rd September 2010, 01:43 PM   #12
audio0,
I wonder the wiring
from I2S output of usb converter to the place, you connected it where in tda 1543 dac
Old 24th September 2010, 09:56 AM   #13
audi0's Avatar
Hi darkfury,
I haven't completed my connection yet, I have a circuit board half finished to combine my DAC receiver IC plus an analogue switch IC so that I can choose I2C or SP/DIF inputs. I'll post photos once completed.
Regarding your query, you will need to break into the circuit board traces between your receiver and converter IC's, something like the drawing below.
Hope this helps!
Old 27th September 2010, 10:51 AM   #14
Thanks a lot of audi0,
Since I have a terralink usb convertor with I2S output(from valab on ebay) just needing to pull out the receiver
I think, We have also have same dac 4*TDA 1543
so, your attempt really interested me
Waiting your results, goodluck
Old 7th October 2010, 01:18 PM   #15
Audi0,
Do I need to desolder CS8412 receiver chip
before connecting the 4*1543's to I2S out?
Old 8th October 2010, 06:17 AM   #16
audi0's Avatar
Hi darkfury,
I think it would be advisable yes, but I would be more inclined to cut the tracks rather than remove the whole receiver chip. That way you can easily re-connect if you need to with a bit of solder.
I am adding a switch to mine to select either I2S or SP/DIF inputs, I'll be etching a board soon.
query Professor smith Multi-Way 2 5th May 2009 01:47 AM
Left-justified I2S to Philips I2S Converter curva Digital Line Level 23 19th February 2009 01:50 PM
PCM2707 -> I2S -> PCM1794 clocking query rja Digital Source 9 4th June 2007 09:21 AM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 05:46 PM
I2S socket query kittaylor Digital Source 3 27th April 2004 12:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
