Any opinions about this discrete DAC ? Any opinions about this discrete DAC ? - diyAudio
Old 9th August 2010, 08:49 PM   #1
tessier is offline tessier  Canada
Default Any opinions about this discrete DAC ?
Hi
Any opinions about this diy discrete DAC ?
Discrete DAC
Thanx
Paul
Old 9th August 2010, 09:57 PM   #2
riktw is offline riktw  Netherlands
looks interesting, using a 74HC595 for I2C decoding, i like it.
you do need matched resistors, take 0.1% and match them yourself.
Old 10th August 2010, 04:25 AM   #3
amc184 is offline amc184  New Zealand
amc184's Avatar
It's a neat idea, and something I've been wanting to make for a long time, but I've never got around to it. On this site someone has made another discrete DAC and posted some results.
A couple of thought of mine on this topic:
- Matching the resistors in the resistor ladder is critical. I would get an accurate multimeter and a whole or part reel of 1206 size 1% resistors of eBay. Use one value of resistor for the whole ladder (one resistor for the 2R part, two in parallel for the R part).
- I would use a discrete, very low Ron CMOS buffer between the logic and the resistor ladder. I would look at using something like IR's IRF7307. This reduces the impedance (and more importantly, the variance in that impedance) of the feed to the resistor ladder by two orders of magnitude.
Old 10th August 2010, 01:53 PM   #4
lcsaszar is offline lcsaszar  Hungary
I experimented with a discrete DAC some time ago. Here is some desription (sorry, it is Hungarian only, but there are some pictures and a circuit diagram at the end):
DDAC project
Old 15th August 2010, 04:56 PM   #5
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
IMO, you are much better off implementing a solution based on one of the many DAC chips from T.I., Analog Devices. or Linear Technology which are intended for high-performance instrument grade waveform-synthesis. While not directly intended for the audio market, a number of these DACs feature excellent A.C., datasheet documented, specs. Digital audio actually is a class of digital waveform-synthesis, if you think about it. MOst of these instrument market DACs use either R2R Ladder or Resistor- String conversion technology.
Their application to audio is not as straight forward as it is with audio purposed DACs. Some of them have serial data inputs while others have parallel. Some accept a 2s complement input data format while others require unsigned straight binary and would need 2s complement formatting logic. In short, you will have to implement you own input data/frame formatting interface logic. In addition, most are what's called multiplying DACs, or M-DACs for short. Which means that they require a reference voltage that can be either D.C. (what our familiar HiFi audio converters use internally), or an A.C. signal which is multiplied with the current data sample input to the DAC so to produce an output which is the product of the two. However, if any of that were a serious concern we wouldn't be considering building our own discrete diy DAC in the first place. would we!?
In any case, while not as simple to use as are actual audio DAC chips, M-DACs are far easier to implement than a discrete diy converter, will have better A.C. specs (THD, SFDR, SNR, FS), DNL, INL, and lower glitch-energy. Best of all they all utilize some form of resistor and FET-switch based converter technology for up through 18-bits and are in active production. I'm not aware of any audio market active production DACs that are not Sigma-Delta, with the exception of the PCM1704. The PCM1704 had been discontinued but was placed back in to active production reportedly because of demand from the instrument waveform-synthesis market. How ironic.
Ken
Old 15th August 2010, 07:10 PM   #6
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Also the best of all DAC chips ever, which is also non delta sigma, is still in production. PCM56.
Old 15th August 2010, 07:24 PM   #7
Hi
Looking more closely at those discrete dac, I will go for a ready-made chip, it's much easyer to use and I still have one TDA1541A chip and a DIR9001 receiver chip.
Thanx guy's
Paul
Old 11th September 2010, 04:47 PM   #8
vincent_brient is offline vincent_brient  France
I am a discrete R2R DAC lover, there are really musical and it is possible to experiment them for very low cost. Even when 1% resistors are used the sound is already good!
Take a CS8412 ot CS8416, some cheap logic chips and 100 1% resistors and that makes a good DAC, better than a conventional midle cost DAC.
Vincent
http://vincent.brient.free.fr/main.htm
Old 17th August 2011, 02:24 PM   #9
gareth is offline gareth  Wales
gareth's Avatar
I have been thinking of making a discrete ladder DAC myself, instead of off the shelf. This would be my first time to build a DAC and I hope to learn from the process and then maybe in time progress onto a discrete I.C. 'off-the-shelf' type. I was wondering how complex it would be beginning to end to make this ladder DAC as the schematics I have seen in the past have not told the full story.
Can anyone give me any usefull information or even where to go to do this. I have a rake of 1% resistors ready for the purpose but wanted to learn more about the full process first. How the waveform feeds into the ladder then feeds out etc etc etc
Old 17th August 2011, 02:49 PM   #10
You can use most part of my discrete DAC, see above. Best method is to convert from I2S to offset binary. Old 14-bit Philips CD players have the SAA7000 chip that can do this conversion. Then you need a serial-in/parallel-out shift register and precision switches + resistors. 1% is good only for proof of concept testing. 2R-R ladder is voltage output, you need a high input impedance buffer and that's all. But don't expect more than 12 bit resolution :-( It's for fun after all...
Any opinions about this discrete DAC ?Hide this!Advertise here!
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 06:24 AM
Discrete DAC i/v stage bocka Digital Source 20 28th May 2010 05:05 AM
Discrete DAC tbrowne Digital Line Level 81 7th April 2009 12:10 AM
discrete DAC Bernhard Digital Source 6 26th September 2008 12:24 PM
Discrete DAC i2s hugobors Digital Source 0 29th March 2007 02:10 PM
Copyright ©1999-2017 diyAudio
