Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th July 2010, 04:49 AM   #1
Default unity gain stable single channel DIP opamp
looking for something to replace two single OPA627 (currently on adapters) I have in the output stage of my DAC
any suggestions would be great!
Old 12th July 2010, 06:27 AM   #2
Mooly's Avatar
There are literally dozens of threads on this subject, however for great sonics I still think the OPA2604 has a bit of magic about it.
You are just going to have to try a few and see what you think.
A simulation free zone. Design it, build it, test it.
Old 12th July 2010, 07:24 AM   #3
Thanks mate - I've read dozens and dozens of threads about this type of thing over the past year or two, but it's the "unity gain stable" thing that gets me - what is the statistic on the data sheet that lets me know whether it is unity gain stable or not?
Old 12th July 2010, 07:34 AM   #4
Mooly's Avatar
Usually mentioned specifically as one of the main features... if not you have to read through the data sheet. There's no "parameter" as such in the specs that indicates it is or isn't... although words such as "internally compensated" usually mean it is, and devices that have "external compensation" usually aren't.
http://www.datasheetcatalog.org/data...wn/mXtutss.pdf
Old 13th July 2010, 05:42 AM   #5
jcx is offline jcx  United States
how can anyone offer meaningful advice without the basics of V or Iout, what signal levels, power supply V?
Old 13th July 2010, 06:13 AM   #6
Mooly's Avatar
The OPA2604 covers most bases having a supply range of -/+4.5 to 24 volts, 600 ohm drive capability and good (it's docile to work with) stability.
As a replacement for the OPA627 (on dual adapters as the OP uses them) I feel it it should operate perfectly in a DAC whether used as I/V conversion/filter buffer etc.
If you want to retain the single devices and adapter use the OPA604
Whether the OP can hear any difference subjectively will be interesting to know.
Old 13th July 2010, 06:48 AM   #7
Sorry, yes, a schematic will help:
I just received my Wolfson 4.0 BIY DAC :)
Old 13th July 2010, 07:18 AM   #8
Mooly's Avatar
OPA604 should be perfect. When you mentioned using adapters thought you meant making a dual out of two single SMD devices.
Read the last part of this data sheet "sound quality",
http://www.datasheetcatalog.org/data...n/mXyzsxss.pdf
that's Burr Browns take on it... in use I have found it offers excellent sonics, can't really say more than that... only you will know if you hear/detect/like the device.
Old 13th July 2010, 07:22 AM   #9
OK thanks, I'll give them a go. I tried out the LME49710NA (as you can read in that thread), but did not notice a huge difference, so it should be interesting to try the OPA604 and compare it with both the OPA627 and LME49710NA.
I don't think there are many other candidates there that would be suitable opamps. I'm leaving the four OPA627 in the filter stage as it's too expensive to replace all 6 chips!
Old 15th July 2010, 07:38 AM   #10
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
remember they also need to be bipolar input for your dac.
mooly, I recommended the BUF634 to lordearl, as I figured they were single channel opamps acting as unity gain buffers (the stock opamp is OPA134), but of course we didnt get good results as they are also taking a bipolar input
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 01:23 PM
BOSOZ unity gain stable AudioAngel Pass Labs 1 21st August 2008 09:20 PM
Opamp question regarding unity gain markiemrboo Chip Amps 12 15th February 2007 03:40 PM
1nV unity gain stable opamp from ADI jackinnj Solid State 7 13th December 2005 06:06 PM
Page generated in 0.10755 seconds (75.83% PHP - 24.17% MySQL) with 10 queries
