| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I'm working on a DAC chip with differential outputs.
I've accidentally lifted L+ and R- pads from the circuit board. Is there any reason I can't use L- and R+ outputs? Would this result in throwing the speakers out of phase? |
#2 |
it depends on the topology of the current sources within the DAC. But most current steering DACs I know must have their outputs connected to a low-impedance current path. For example You could use a single DAC-output of the PCM1794A (and alikes) if You connect the inverted partner output to gnd. jauu Calvin |
#3 |
This is a CS4397 that has voltage source outputs.
#4 |
RIP
Yes, your speakers will be 180 degrees out of phase.
#5 |
Managed to tap the L- and R- pins right on the chip.
I need to stop screwing with this DAC.
| Differential outputs as source for gainclone? | terranigma | Chip Amps | 8 | 4th April 2008 05:56 AM |
| please advise.. ext. LPF summing differential outputs by an opamp | ASSaBeong | Digital Source | 0 | 17th May 2006 11:15 AM |
| Please advise a 20- or 24-bit Audio Codec with Differential Inputs/Outputs. | skpb | Digital Source | 2 | 9th January 2006 03:27 PM |
| Page generated in 0.06924 seconds (74.31% PHP - 25.69% MySQL) with 10 queries |
