Need to source Mu-metal cans
Old 6th July 2010, 12:01 AM   #1
phrarod is offline phrarod  United States
Default Need to source Mu-metal cans
I'm having some interstage transformers made but the manufacturer doesn't have any access to mu-metal cans.
Anyone know where I could find cans roughly 2.25" D x 1.75" H
Old 6th July 2010, 01:52 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
only mu-metal I have ever seen
Ultraperm MUMetal Shielding Sheet 0.15mm, 31.5cm x 19.5cm 80% nickel | Diy HiFi Supply
sometimes we know very little, and sometimes we know too much
Old 6th July 2010, 01:54 AM   #3
I have sheeting but its not as good as a can unfortunately.
Old 6th July 2010, 02:11 AM   #4
jcx is offline jcx  United States
low carbon steel is lower perm but much cheaper, more available, formable - use a couple iron cans nested with air-space
if its hum you're trying to attenuate then a iron box around the supplies might be a good start
Old 6th July 2010, 03:28 AM   #5
jackinnj is online now jackinnj  United States
jackinnj's Avatar
You wanna demonstrate that with some data?
Old 6th July 2010, 03:32 AM   #6
only real world experience. I would have to somehow weld it into a can shape. Wrapping the transformers did next to nothing. This is why mu-metal cans are used in these applications - Jensen, Audio Note, on and on. Wish I could get away with just mu-metal sheeting. Would make things easier.
Old 6th July 2010, 04:26 AM   #7
max426 is offline max426  United States
max426's Avatar
Check this link. Download the PDF catalog
ZERO Manufacturing, Inc. - Deep Drawn Enclosures
jim
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP
Old 6th July 2010, 04:27 AM   #8
Thanks. I'll check it now.
Old 6th July 2010, 01:23 PM   #9
jackinnj's Avatar
Which mu-Shield foil are you using? You can wrap several layers on a former, insulated from the transformer. Separate each layer (you can use mylar tape) I've had very good luck with MuShield.
Have you identified the source of the radiation? Perhaps changed the orientation of the source? Shielded the source with absorptive material. I have an EMI sniffer which will pick up line radiation and an RFI sniffer -- in particular, the EMI sniffer can be hooked up to a selective voltmeter (I have it on a HP Spectrum Analyzer) and you can pinpoint the source of the radiation.
Old 6th July 2010, 03:37 PM   #10
I have not tried that but would love to try those sniffers. Are they expensive?
Need to source Mu-metal cansHide this!Advertise here!
BUF03 metal cans and SAA7220 P/B's audioman54 Swap Meet 15 24th December 2010 09:02 PM
Source for Toroid cans?? Zero Cool Everything Else 2 19th October 2008 06:37 PM
transformer cans/ covers source mikecj Parts 5 7th January 2008 06:55 PM
Source for metal speaker ports jamesjung21 Multi-Way 8 26th December 2007 06:13 PM
amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? siu sin man tho Digital Source 0 17th March 2004 01:31 PM
