Need to source Mu-metal cans - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th July 2010, 12:55 PM   #21
phrarod is offline phrarod  United States
You're educating me that's for sure. It might kill the project and I'll have to find a transformer source who already has them in a can
Old 1st September 2010, 10:07 PM   #22
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I read this with much care and after some investigation I now understand Mumetal cans work not by diverting magnetic fields but by shunting them.... (to GND ?!)
Is it necessary to connect a mumetal cage to gnd in order to work properly ?
I have been experimenting with iron versus aluminium lids and found that a layer of iron near the magnetic source covered by another (alu) is better than the reverse (alu near the tx and iron on top). The gains are evident even without connecting the lids to gnd.
In the case of mumetal, can I expect a similar behaviour ?
Ricardo
Old 2nd September 2010, 12:30 PM   #23
jackinnj's Avatar
If you don't attach the shield to gnd you essentially have the shield as one plate of a capacitor and the ground as the other plate. Thus, there's an electrostatic potential between the two plates.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 2nd September 2010, 12:53 PM   #24
nhinstruments
RCruz's Avatar
My best results are obtained with the plates connected to GND but I also get very good results just by covering the circuit with an iron plate.
I have read that severall thin plates work better than a thick one... these should be placed with a dielectric between them (air).... In this case I should connect all plates to gnd right ?
Old 2nd September 2010, 02:28 PM   #25
qusp is offline qusp  Australia
qusp's Avatar
love the ZERO link! thats excellent. contemplating getting some of the mini enclosures and the deepdrawn cans. the mini flanged mumetal lids could be designed into a PCB with the mounting holes and grounding pads to cover a dac chip. I know the gains are unlikely to justify the means, but hell if nothing else it'll look sweet
Old 3rd September 2010, 02:29 PM   #26
nhinstruments
RCruz's Avatar
Is Mumetal good for source shielding ( as well as target "sensible equipment" shielding) ?
I read that we need different materials to shield strong and weak magnetic fields.
Old 3rd September 2010, 02:57 PM   #27
PigletsDad's Avatar
The problem with wrapping things in sheet, or indeed making a DIY can from mumetal sheet, is that the permeability of mumetal drops massively after mechanical work. For high performance use, it is first made into the target shape, then given a special annealing cycle under a hydrogen atmosphere to restore the magnetic properties.
This is why decent shielding cans are so expensive. I used to work in a physics lab, and had mumetal shields for one of my experiments; they were very effective, but cost over 1000 - say $1500.
Second hand or surplus cans may be your best bet.
I know that Sowter transformers offer shielding options on some of their transformers, and will sell you empty cans.
Old 3rd September 2010, 05:15 PM   #28
nhinstruments
RCruz's Avatar
Thank you.... I will look for Sowter TX
Old 3rd September 2010, 05:40 PM   #29
jcx is offline jcx  United States
low carbon steel/iron is cheap so you can use lots, heavy sections, air spaced layers and get good mag field attenuation practically and much cheaper than with exotics like mu metal
also you need to think of mag shielding as diverting the field - Fe is 100s-1000s of times more permeable than air so the mag field wants to "shortcut" through the iron
you could even use cast iron plumbing pipe fittings to make up shielding cans for small xfmrs - just don't try to take them on airplanes
Old 3rd September 2010, 05:56 PM   #30
nhinstruments
RCruz's Avatar
No airplanes in my mind... yet
Just need to shield the IEC inlet in my phonos..... Too near to the right riaa board input load resistors.... picks up like an antena
BUF03 metal cans and SAA7220 P/B's audioman54 Swap Meet 15 24th December 2010 08:02 PM
Source for Toroid cans?? Zero Cool Everything Else 2 19th October 2008 05:37 PM
transformer cans/ covers source mikecj Parts 5 7th January 2008 05:55 PM
Source for metal speaker ports jamesjung21 Multi-Way 8 26th December 2007 05:13 PM
amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? siu sin man tho Digital Source 0 17th March 2004 12:31 PM
Copyright 1999-2017 diyAudio
