Help needed on Gigawork DAC !!!
Old 16th April 2012, 12:59 PM   #11
mavallarino is offline mavallarino  United States
mavallarino's Avatar
Originally Posted by nick974 View Post
Hi Everyone !
I completely forgot to give the final result... I was able to get it to work ; the power supplies were not connected connectly, and the relay was always shorting outputs to ground.
I haven't tested out the SPDIF connection but the USB works fine ; I have replaced the AOPs, sound is much better ; I haven't made any other modifications... But I was thinking to remove the second amplifier stage, and the connection through the relay.
I will test it out as soon as I have some spare time !!!
Regards.
Looking closely at Nick's solution I was wondering what exact problem he had found on the power supplies. I'm having a related problem with the relay switching (grounding outputs) after 2 min. from start up (however on a CS8416). The only connection to the relay from the controller chip is an "input port controller". Must there be voltage on this?
Old 17th April 2012, 09:13 PM   #12
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
To work correctly, DIR9001 must be connected to that resistor
What will happend if it is not connected?
Im running mine without it connected.
Regards ke
Help needed on Gigawork DAC !!!Hide this!Advertise here!
New Small DIY Gigawork Dac? jeffjazz Digital Line Level 254 13th April 2013 01:04 PM
Gigawork Upsampling DAC w USB psemeraro Digital Line Level 54 28th November 2012 09:25 PM
snow48 cheap gigawork "clones" - anybody tried? Galgo Digital Line Level 2 11th June 2010 09:37 AM
Do you have a Gigawork DAC? Is this a mistake? ciagon Digital Source 4 8th March 2010 04:29 AM
DAC - Opinion needed Faust3D Digital Source 45 20th November 2007 09:25 PM
Copyright ©1999-2017 diyAudio
