| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | ||
![]() Quote:
#22 | |
MUSIC PLAYING: With digital signal in the input VU meters are hovering around -2 db, just below clipping. I have also noticed that channels 5 and 6 are constantly clipping when playing the signal with top bar illuminated red at all times. Note I am only using channels 1 and 4 for output, 5 and 6 are not being used at all. Muting 5 and 6 does nothing. Muting 1 and 4 gets rid of the distortion but also the music. |
#23 |
Tried a new setup using channel 1 and 3 output. Same problem (heavy distortion + clicks and pops from left channel) however channel 5 and 6 VU meters show no signal so must have been a dodgy setup earlier.
#24 |
#25 |
OK, good test. It's not idle noise but something related to signal.
Do the clicks and pops come at any time, or only on peak levels? Do you have any EQ turned on? It's possible to boost the unit into clipping with EQ boost. Generally the level is lower on the outputs than the inputs when using just crossovers. Without any level or EQ boost, the outputs will not clip if the inputs don't. And the digital input only clips if the digital recording is clipped. I rarely see that. Do you see any relation between the noise and the VU meters? If you can get spdif out of your computer or simply burn a CD, I can supply some test tones for you.
Take the Speaker Voltage Test! |
#26 |
ALSO Quoting.....
I'm no expert here, so my math could be wrong. I think 6dB represents 1/4th" -------------------------------------------- Pressure and voltage are "20 log" quantities, while power is a 10 log quantity. So, -6dB would be 1/2 the voltage or the 1/2 the SPL, while it would be 1/4 the power Last edited by WithTarragon; 25th June 2010 at 03:03 PM. Reason: .... |
#27 | ||||
#28 |
And I believe you are absolutely right. I don't know what the trouble is, but it is definitely faulty.
You should return it. Let them know that you have tested it and it's not supposed to do that. A normal unit might have a little hiss, that's all. Good luck!
#29 |
is choosing a less facetious title...
guys i'm not familiar with this device, but is there a buffer size setting like on most pro and semi-pro audio interfaces? I would think there is, and these clicks and pops sound like it is related to memory overrun. if there is somewhere to make the buffer size larger, do that, you should be able to do it live while music is playing.
I apologize if this has already been covered. doesnt explain the distortion underneath, but we could be seeing 2 separate problems here I agree with the above though, it does sound like a dud unit. link him to this thread if he gives you any lip |
#30 |
The shop I bought the unit from offered a straight swap so i'll exchange it later this week. Thanks for the help guys, I learnt a lot in the process.
Regarding digital input and attenuation after the DCX, can anyone recommend a good value 6 channel attenuator? If I can't find a decent priced one I may have to consider 3 x 2 channel stepped. |
| DCX2496 digital input pins? | nonsub | Digital Line Level | 0 | 19th March 2010 03:28 AM |
| P3A strange problem (thumb when applying input signal) | habitbraker | Solid State | 4 | 26th February 2010 11:49 AM |
| DCX2496 digital input question | honfatboy | Digital Line Level | 11 | 31st October 2006 06:26 AM |
| DCX2496 bass signal | compact7 | Digital Line Level | 0 | 7th April 2006 05:01 AM |
| DCX2496 input A losing signal constantly | mazeroth | Digital Line Level | 5 | 14th February 2006 06:46 AM |
