Best and final TDA1541A output stage
View Poll Results: What's the best output stage for TDA1541A based DAC
Opamp 12 16.90%
Discrete Solid State 23 32.39%
Lampizator-style 13 18.31%
Cathode Follower 1 1.41%
Thorsten-style 10 14.08%
Other 12 16.90%
Voters: 71. You may not vote on this poll
Old 25th July 2010, 12:32 PM   #11
studiostevus is offline studiostevus  Netherlands
Seems we have a winner...: Discrete solid state.
Unfortunately this still leaves a lot of room for different concepts... I have read a lot of good stuff on Pedja Rogic' output stage, and thinking about building that one. Good choice? I have never designed a PCB before, so would this one be good for a beginner?
Old 25th July 2010, 02:09 PM   #12
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Pedja Rogic used a AD844 in a non standard topology. Very nice but it won't qualify as "discrete" if that's what you're after. He was not too keen on other people using his design (commercially that is ) AFAIK. You can find the schematics at his website.
Rudolf Broertjes designed a nice discrete stage but I never made one working as I got lost in the different versions for TDA1543, TDA1545 and TDA1541A. That one is fully discrete and Leo from diyparadise.com uses a version on his Monica TDA1545 DAC. It is supposed to sound very good. It will take time to find the right version for TDA1541A I think.
http://www.tnt-audio.com/sorgenti/monica2_mods_e.html
http://diyparadise.com/shop/index.ph...products_id=61
edit: the link on that webpage to the schematics etc. does not work ...
BTW I found this webpage from a fellow dutchman:
http://home.wanadoo.nl/dezaire/CD80mod/IV-omzetter.htm
The remark of the author that cdplayers nearly all sound the same is somewhat suspicious though I would design a nice PCB instead of the heap of parts glued together too.
It's only audio. Member of the non modular PCB design committee
Old 10th September 2010, 02:39 PM   #13
philpoole is offline philpoole  England
Hello everybody!
I voted for opamps.
Although I still yearn to build a decent solid state I/V - my previous attempts have been disastrous.
Op-amps are very simple to get started with and can be very good when done with care.
My dual TDA1541A with PMD100 (8x OS) works well with opamp IV and bessel filter.
(But I'm still keen to try discrete one day - should I ever get round to it).
Old 10th September 2010, 03:01 PM   #14
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Papa Pass has a new article that should interest you....... The Zen I/V converter
http://www.diyaudio.com/forums/diyau...converter.html
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 14th March 2013, 04:42 AM   #15
HP8903B is offline HP8903B
bump
Best and final TDA1541A output stageHide this!Advertise here!
Your Favorite Output Stage for TDA1541a ? riotubes Digital Source 3 8th January 2013 11:13 AM
Completely differential amplifier final stage exeric Tubes / Valves 14 28th April 2010 06:21 PM
The CMP Final Stage Stee Solid State 0 23rd December 2008 05:49 AM
Final Stage of Building UcD400 ruangrit Class D 3 29th November 2005 01:01 AM
increase the bias current of an opamp final stage herve Solid State 19 15th September 2003 12:29 PM
Copyright ©1999-2017 diyAudio
