PCM1798 - looking for advice on cheap and simple I/U - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th June 2010, 03:54 PM   #11
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by SoNic_real_one View Post
Sure, if the PS is so bad that will induce noise in the outputs, the PS is the point of improvement. I see here people that complain about hum, ground loops and such. Yes, OpAmps won't make a difference there.
Well I've moved a little way beyond having hum as a problem in my DAC designs
But if we are talking about TDH+N below -60dB, the cheap, "bargain" OpAmps are the weak point. In all my mods that involved swaping OpAmps in existing DAC's, the results where noticeable - from 'wow' to just a slight change.
Not having bought or built myself a THD analyser, I couldn't be sure that that's the change I'm seeing. I have had rather strange audible effects with NE5532s in my current DAC exploration though, to be mentioned in my blog in due course. Never had a 'wow' change from swapping an opamp in an I/V conversion job, but they're the most sensitive ones IME.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 15th June 2010, 05:27 PM   #12
kevinkr's Avatar
I recommend you consider a TI differential amplifier like the THS4131 which sounds amazingly good with both the PCM1798 and the PCM1794A. This is what I used in my dac, and then a line to line (600:600) transformer to convert the differential output to unbalanced. This is the best sounding combination I have yet heard.
Operational Amplifier (Op Amp) - Fully Differential Amplifier - THS4131 - TI.com
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 15th June 2010, 06:25 PM   #13
Alexium is offline Alexium  Ukraine
I've heard about this opamp, but it's extremely hard to find where I live (not to mention it's quite expensive).
Old 15th June 2010, 08:18 PM   #14
Sign up for TI's excellent sample program. It's very easy and the THS4131 is avaliable as samples now. You can also get PCM1798 and OPA1632.
Old 15th June 2010, 08:25 PM   #15
From what I've heard, they're not sending free samples to my country anymore.
Old 15th June 2010, 09:05 PM   #16
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
нема ніякої проблеми дістати 4131, я їх юзаю в одному з моїх цапів і регулярно купую, як треба то звертайся.
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) S-Audio.Systems
Old 16th June 2010, 03:48 AM   #17
abraxalito's Avatar
What values of input and feedback resistor are you using? It looks a little bit limited in the choice of Rfb.
Old 16th June 2010, 03:51 AM   #18
abraxalito's Avatar
For audio it would be a bit daft to use the 4131 As far as I'm aware, the OPA1632 is the same part but targetted at audio rather than instrumentation so probably tested a little differently. And around half the price
Old 17th June 2010, 09:28 AM   #19
Nazar_lv's Avatar
1632 is lower quality parts of 4131
I use 390 with 1794A. But simple put 4131 as I\U converter for DS DAC is really not good, dac glitch and HF noise terribly reduces sound quality)
Old 19th October 2010, 09:41 PM   #20
Klim is offline Klim  Ukraine
Klim's Avatar
What do you mean?
What measures are needed to filter glitch similar to those used in Picardian Chord?
Or that the application THS4131 in conjunction with the DS DACs, in particular the PCM1794, does not sound good at all?
What do you use for a simple cheap load? digital desire Solid State 30 30th December 2006 11:04 AM
The cheap simple ClassD TroelsM Class D 30 25th October 2005 10:24 AM
Simple and cheap sparkle Solid State 33 14th May 2004 06:19 PM
Copyright 1999-2017 diyAudio
