| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all,
I have a few spare DSP boards left from a past project, they would nicely fit now a new Xover project. I'm thinking of writing a computer application + DSP firmware that would allow the user to set crossover filters, parametric EQ, delay lines and gains, in order to resell these boards that i'm not likely to use. The purpose of this thread is to poll the interest of potential buyers and collect requirements before starting to work on it. What i'd like to know is: - Is there anyone interested in such a board? - What kind of processing should i make available, apart from Xover (Buuteworth/Linkwitz-Riley/Bessel up to 48dB/oct), PEQ, shelving filters, delays and gains? - What form should the project take? Me doing the whole stuff in a closed and controlled manner, or releasing an open-source framework? - Whatever comes to your mind. Here are some details about the board itself: ![]() - The DSP is a Freescale DSP56321 clocked at 275 MHz. It's capable of 275 MMACS, has a coprocessor and boasts plenty of RAM, enough to make a 4 second delay line at CD sampling frequency. The DSP is 24-bit fix-point with 56-bit accumulators. It's been a classic architecture for years in DSP for audio processing, and i guess that many of you have some custom code for it. 275 MMACS is A LOT! Enough for steep crossover filters, countless PEQ or FIR filtering. - There's a USB connection allowing transfers of data to/from PC up to 8Mbit/s (USB High-Speed). The controller chip is manufactured by FTDI. - There's a codec onboard with 2 analog inputs and 6 analog outputs. The chip is by Analog Devices ref. AD1838A. ADCs and DACs have both over 100 dB dynamic range, inputs and outputs are balanced or unbalanced. There are plenty of clock options, with 2 quartz onboard switcheable from the DSP. - There's an expansion connector for separate I2S in and out, SPI and GPIO. Everything is there if you want to drive your own ADCs/DACs/SPDIF tranceivers. - There's an other port with 5 outputs and 3 inputs for leds and pushbuttons. - JTAG is also onboard if you wish to write your own code. - The board requires 5V and +/-12V. The rest of the power supply is included on board with quality TI regulators. I can supply the matching SMPS. - Finally, it's a high-quality board with 6 layers, vast ground planes and branded chips. Best! chaparK Last edited by chaparK; 23rd May 2010 at 03:11 AM. Reason: Added pic |
#2 |
looks like a very interesting board! You might want to get one of the moderators to move the thread to the "swap meet" section though as you are talking about sales. Would be nice to have a 3 or 4 way DSP crossover with linux opensource software for setting up
Nice to have all balanced connections!col.
http://www.minirig.org.au |
#3 | |
I just checked the data relative to the codec: dynamic range is 105 dB for the ADCs, and 108 dB for the DACs (A-weighted). Pretty usable. The pic shows the prototype. Production boards are red and have screw terminals for the power supply leads. So far i'm not selling anything. Just gathering suggestions and interest. It's not a topic for selling anything, but for discussing what would be cool to have in the software
#4 |
yeah the board looks great! Iv'e been watching the miniDSP stuff a bit and would have probably invested long ago if it wasn't for the fact that there is no balanced connectivity and the plugin software runs on windows. What about making the setup software using something that is multi-platform like Java? Also, for pro audio use it would be better if it was 4 way.
col.
#5 | |
- 4-way crossovers - Multi-platform I have to say that i had in mind to make a Windows app as well. But you're right: the app should be multi-platform. Don't like Java though. Maybe Python? I know there's a Python wrapper around the FTDI API for USB com. Haven't tested it though. |
#6 | |
I previously posted the following wish-list in another thread (so not all relevant to your hardware):
Bohdan, the author of SoundEasy loudspeaker design software, wants to partner up with someone who can provide the DSP hardware for his latest DSP utilities. See SoundEasy product page. I'm very much interested! Good luck with this project.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#7 |
very interesting indeed. do you have a rough idea of what it will sell for?
ive just bought a miniDSP + MiniDigi board to play with, and so far im fairly impressed, though its not without drawbacks. the first being (as col says) only windows interface - luckily i do have a windows box to program it, but ideally i'd want something i can run from a mac (which is my audio workstation). the interface is very pretty, but very 'laggy' when running live to the board (no big deal, set it up offline then sync) also, if you are going to make a pretty graphical interface, then it ought to be editable graphically - not just from edit boxes. that said, give me raw functionality over pretty interface any day. the ability to edit the parameters of say, parametric EQ's, live - so if you are eq'ing a system, you dont have to edit the setup file, download the board, recheck your freq response, edit params, download, etc. its important (imho) to be able to make changes in real time. this is something you can do with the miniDSP the miniDSP 'plugins' system is a bit weird. I'd rather just pay more money upfront and have all the options of all the plugins available as settings, rather than be limited to whichever particular optionsets they decide they will include in a given plugin. eg the ability to choose whether to use a graphic eq or a peq at a given point in the signal chain. one bit of *essential* functionality missing from the miniDSP is output limiters. anyway, count me in as interested (if the price isnt too high) I second Col in saying Hooray for Balanced ins and outs... cheers, ben |
#8 |
#9 | |
col.
#10 |
No, it is just the factors that were foremost in my mind at the time, not in order of preference. I had been investigating the requirements for a DSP-based active crossover for my Meridian D6000 speakers which I bought minus the DSP board. I have actually purchased the DCN23 from GroundSound. I have yet to build the amplifiers, though.
I am very much pumped about DSP audio since I started enquiring about them.
| Violet DSP Evolution - an Open Baffle Project | cuibono | Multi-Way | 211 | 18th May 2010 02:26 AM |
| RS-232 cable for DSP-Amp Digisynthetic DSP-1400 | Sabbelbacke | Parts | 0 | 9th May 2009 09:33 AM |
| Xover advice for first 3way project | silvercans | Multi-Way | 1 | 29th October 2005 11:56 AM |
| Software digital DSP ... Xover/filters/EQ ?? | JinMTVT | Digital Source | 2 | 8th October 2004 06:02 AM |
| DSP card & proper xover for heathkit 859A speaker cabinet | x. onasis | Multi-Way | 6 | 22nd April 2003 07:39 PM |
| Page generated in 0.14771 seconds (84.96% PHP - 15.04% MySQL) with 11 queries |
