Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd May 2010, 10:52 PM   #1
novec is offline novec  Norway
novec's Avatar
Send a message via MSN to novec
Default Balanced AES/EBU (SPDIF) input circuit (to DIR9001)
I'm building a DAC with a DIR9001 receiver, which will be fed balanced AES/EBU from a Lynx AES16 sound card. Problem is, I haven't been able to find a balanced input circuit anywhere. And believe me, I've searched...
Anyone have a balanced input circuit? No transformers, it's already transformer coupled at the sound card.
Old 22nd May 2010, 11:37 PM   #2
RIP
Look at the CS8416 datasheet.
Old 23rd May 2010, 01:50 AM   #3
stokessd's Avatar
Page 49 of the CS8416 data sheet has what I've seen for the last 20 years, but I only ever have used Crystal receiver chips.
http://www.cirrus.com/en/pubs/proDat.../CS8416_F3.pdf
Sheldon
Old 23rd May 2010, 12:49 PM   #4
novec's Avatar
Thanks a lot, but I'm afraid it doesn't help me much with the DIR9001, as it only has single ended input. I guess it's possible to do an AES -> S/P-DIF conversion first, and then do a single ended input circuit, but I'm sorta hoping there's a better way...
Old 23rd May 2010, 01:01 PM   #5
The two of the usual suspects for this job are the 26LS32 and the SN75176.
Old 23rd May 2010, 01:21 PM   #6
stormsonic's Avatar
@novec
If output od your soundcard is transformer coupled, signal on secondary is already balanced
Better to think about right transformer, how to make correct impedance, signall attenuation, right connector and reflections from DIR9001 input.
Schmitt trigers are nasty
Nice reading here:
LINK 1
LINK 2
Old 23rd May 2010, 01:23 PM   #7
Algar_emi's Avatar
AES/EBU balnaced input to Bal/single ended is done with a digital transformer, and is easy to find everywhere. Check Twisted Pear Audio, their SPDIF 4:1 Mux. The schematic shows a good way to implement it.
Old 23rd May 2010, 01:39 PM   #8
ghg is offline ghg  Austria
ghg's Avatar
Not that cheap ( ca. $ 50,- ), but perfect:
Neutrik - Audio - AES/EBU Impedance Transformer
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 23rd May 2010, 01:50 PM   #9
RIP
AES/EBU and SPDIF are virtually the same thing. Use a proper pulse traf and terminate it correctly, and ground one side of the secondary to digital ground, there is no other way AFAIK, except to ground one conductor through a cap.
Old 23rd May 2010, 05:23 PM   #10
Originally Posted by Bill Fuss View Post
AES/EBU and SPDIF are virtually the same.
Aside from the different flags and the vastly different voltage levels. At least one of my dacs won't work properly with pro flags and a lot of AES/EBU inputs will not respond to the puny SPDIF levels.
Digital SPDIF-AES/EBU interconnect Nuuk Digital Source 3 11th April 2012 07:22 PM
Pulse transformers SPDIF/AES-EBU Kurt von Kubik Digital Line Level 14 14th November 2009 04:50 PM
AES/EBU to SPDIF coax input, how? tubenut Digital Source 48 16th February 2005 07:45 AM
SPDIF to AES/EBU Kari Digital Source 4 21st February 2004 11:29 PM
DIGI balanced AES/EBU -> SPDIF Coax meta Digital Source 3 26th May 2003 05:51 PM
Page generated in 0.11060 seconds (78.18% PHP - 21.82% MySQL) with 10 queries
