| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
The loadresistor is 36 Ohm as per Doedes instructions. (180 Ohm/ dacboards) I have no clue what output impedance it has. I'm just thinkering and has implementied an idea I've had for a long time. The transformers are connected in a 1:2 configuration. Per Lundahl advised against connecting the secondaries in parallell. This gives me a little bit high output voltage, but my preamp doesn't seem to mind.
Geir |
#12 |
RIP
Didn't they recommend a resistor load for the trafo? That's surprising if they didn't.
#13 |
When used as an input transformer they recommend a source impedance of 600 Ohm and load impedance of 10KOhm.
I didn't think much about that because I used it mostly to be able to use balanced cables and thought that when used in a parafeedconfiguration that would be irrelevant. The loadresistor is placed across the primaries and not the secondaries as I've seen in other implementations. Geir |
#14 |
RIP
I think the issue would be taming the resonance of the trafo at elevated frequencies. You might want to experiment with a secondary load with an added resistor of 10k or so. Just a thought.
#15 | |
I think this forum's Steve Eddy is a big transformer fan. You might want to search around for some of his posts. Last edited by paulb; 22nd May 2010 at 02:43 AM. |
#16 | |
What strikes me across all the different 'neighborhoods' of audio, whether moving-coil-stepups, tube-amp-outputs, etc --- is that a properly calculated Tx is often worlds better than other approaches. This is from listening; in reference to tx-coupling dac outputs, as you remark, no, I don't know much, but I notice it's not a completely unknown or undiscovered strategy. So thanks, I'll try searching some SEddy posts. |
#17 |
My friend is going to mod my Lector cd player with the Superclock 4 and transformer coupling with Lundhal transformers. I am dropping it off to him today, I will post my impressions of what has happened to the sound.
He has turned me on to transformer coupling, he does not like caps, his preamp is transformer coupled 26 tubes and my God that thing is glorious!. Also Reference Audio Mods is now doing mods that include transformer coupling with either copper or silver transformers. He uses Audio Consulting transformers, which may be his own brand. There definitely is something to transformer coupling that I love, of course all the transformers I have heard used in this way were either, Tango or Black Art, all very high end trannies, cheap trannies might do more harm than good. All I know is that I was a changed man when I heard what transformer coupling does! Mike |
| Transformer Coupling Questions | audio_moksha | Tubes / Valves | 6 | 15th January 2008 08:14 PM |
| 6SN7 with transformer coupling | DRC_YUN | Tubes / Valves | 1 | 26th October 2007 03:43 PM |
| DC coupling for DACs | _atari_ | Digital Source | 55 | 23rd August 2007 08:32 PM |
| Question on transformer coupling S-PDIF | Porksoda | Digital Source | 30 | 21st December 2005 02:11 AM |
| transformer basics | dvdwmth | Parts | 3 | 11th April 2004 05:25 PM |
| Page generated in 0.09355 seconds (77.60% PHP - 22.40% MySQL) with 10 queries |
