DAC gallery - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd November 2012, 10:41 PM   #51
dddac is offline dddac  Germany
Default the new DDDAC1794 NOS 192/24 DAC
In the past year I have been working on my new project: designing a DAC which will play 192kHz / 24bit material from a PC (or Mac...) There are many DACs who can do this, but I wanted to design a NOS version, as so far, every listening test I did, this led to a more open, natural and detailed sound.
I found this to be possible by using the well known PCM1794 and avoiding the digital filtering built into the chip. This proved to be quite tricky, but I managed to find the key to do it. It has been a great adventure with much to learn and a fantastic result at the end....
I give a very detailed report on www.dddac.com
you can download the specifications here: dddac1794_nos_ver30.pdf
and below I share a few Pictures. I will also open a thread for discussion on the NOS PCM1794 topics
www.dddac.com
Happy listening and building
Old 22nd November 2012, 10:47 PM   #52
In order of appearance:
The Mainboard with I/O and I2S to right handed conversion
The actual dual mono DAC Module (can be stacked parallel)
Built up with 4 modules and two power supplies (5 and 12 Volt)
Wired up in Chassis (Mundorf Gold silver oil Output and optional Sowter 1:2
The DAC in my Audio rack
another view inside
www.dddac.com
Old 22nd November 2012, 11:07 PM   #53
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Wow! Super great diy! I had already seen your website as was very impressed by it
CE-Designs.net
Old 17th December 2012, 02:54 AM   #54
Default Dual Mono BIII / Hi-Fi 2000 Modushop
I finally finished my dual mono BIII. Oddly enough this build was financed after I built a turntable (Lenco) and sold a pricey belt drive.
I have a Denon 3910 modded to export I2S/DSD to the DAC. I am also waiting for my GB Amanero USB module.
DAC: BIII's with Legato's.
Enclosure: Hi-Fi 2000 Pesante 3U with optional drilled base and fully vented top cover.
Modushop machining (LCD cavity, LCD mount holes drilled & tapped, encoder knob cavity)/engraving.
Anodize after machine.
Arduino control with HiFiDuino/Corpius code.
Apple remote.
Corpius shield.
electroFUN I2C LCDextra IO to reduce LCD wiring.
I did the color fill of the front panel engraving using Testors enamel. I drilled/tapped holes for the Arduino/IR receiver so they are not as nice as modushops CNC work. The rear LCD cavity was to get the LCD closer to the face of front panel.
Old 6th March 2013, 01:32 PM   #55
I'd like to make a request that everyone posting DAC project photos please include the identity of the vendors of the major commercial sub-systems. For example, metal casework and knob vendor, DAC module vendor, etc. Not a full B.O.M., just the 4 or 5 major hardware elements. In particular, I'd be interested in knowing who are the casework and knob vendors providing you with such professional looking enclosures. Thanks.
Ken
Old 7th March 2013, 03:31 PM   #56
Good point! my DAC is obvious I hope
the chassis is from Schaefer. there is link on my website ...
Click here
www.dddac.com
Old 4th April 2013, 09:38 PM   #57
just another multi tda1543 dac. 12 stacked, lm317 reg and deode's i/v values on carbon comp. russian 4uf pio (or piwax? best sounding russian caps ive come across in that theyre actually listenable without killing the resolution. ) copper shielded wires and te8802 usb chip. 8802 sounds comparable (not as good tho) to waveio but has reliability issues.. Click the image to open in full size.
Old 12th April 2013, 12:35 AM   #58
Just an USB-DAC prototype.
I2S from Edel USB interface clocked by DAC (two Crystek CCHD-957);
AD1955;
I-V and LP on OP-AMPs buffered by emitter followers.
An quite unimpressive device:
And a couple of spectra (1063 Hz, -0.15 dB FS; 192/24) for both channels measured with notch filter:
Old 5th May 2013, 01:47 PM   #59
nvduybom's Avatar
Hello ,
My dac just finished .
I use Amanero usb + Ian FIFO Kit + Buffalo III SE.
http://www.vnav.vn/forum
Old 5th May 2013, 02:11 PM   #60
Stixx is offline Stixx  Germany
Stixx's Avatar
Default ES9023
The second DAC that I built is a ES9023 based DAC with one of JP's first boards... (still waiting on the last version to come out ). Powered by a Salas shunt reg, case is from Hifi2000.
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 06:10 PM
Copyright 1999-2017 diyAudio
