DAC gallery - Page 23 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th October 2016, 02:51 PM   #221
Malefoda's Avatar
Send a message via MSN to Malefoda
Nice work, can you detail all the boards used?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 26th October 2016, 06:17 PM   #222
Sure,
It starts with an RPI, with Ian's little U.FL adapter on it, 3 coax goes to Ian's I2S FIFO than I2StoPCM board. Those are stacked on each other. Than my little DAC board comes, that is version x of my AD1865 boards. I found LM431 power supplies on board to be a good solution. I have 2 of them on the board, for the analog +- and the digit +.
The DAC runs in current mode, the termination resistors are not visible, under interstage the transformers on the analog board. The analog board is not a PCBA, it is just a cnc cut board, the traces are wires. The analog amplification has tube rectification and AN copper foil caps on output. In the middle, there is the tube filament power supply board with additional RC filtering. The toroid feeds that and the tub rectifier of the analog amplifier.
There are 2 more power supply boards, one has a dual output about 9V and a single 9V for the DAC board analog and digit board (not 5, because there is regulation on the DAC board). Last, between the toroid and the DAC PSU on the right, there is a 5V supply for the PI and the digital line boards.
I need to replace the toroid.
Than I will replace the DAC board to analog board and the analog board to cinch connector analog cables to AN KSL cables.
And the tubes too. At the moment I have old used tubes from my drawer, I will get some new tubes into it.
JG
Old 26th October 2016, 08:55 PM   #223
Malefoda's Avatar
Thanks, very inspiring.
Old 3rd November 2016, 03:00 PM   #224
easphyx is offline easphyx  Bulgaria
easphyx's Avatar
PCM2707 + PCM1793 + OPA2134 for post-DAC filter + LMH6643 power op amp for headphone output.
Negative rail is provided by LM2662MX (modern more powerful version of ICL7660) switched-capacitor converter. Both negative and positive voltages are filtered via damped (Q about 1) LC filters.
Full project data: https://github.com/e-asphyx/usb_dac
GitHub profile
Old 27th November 2016, 10:41 PM   #225
McGyver is offline McGyver  Poland
McGyver's Avatar
The latest implementation of my PCM1794 based tube output DAC:
Digital filter SLOW/SHARP switch:
Old 18th December 2016, 10:51 PM   #226
What schematic and tubes did you use for the PCM1794 output?
Old 19th December 2016, 12:18 AM   #227
sesebe is offline sesebe  Romania
My creations has photos here: My second try on digital side
Old 9th February 2017, 09:30 AM   #228
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Send a message via Skype™ to dady
Default Tri DAC + nanoDigi
With balanced transformer.
Soekris + nanoDigi
Works!
Esteban Bikić
Old 10th February 2017, 04:27 PM   #229
Default dam1021 dual-mono with bal-bal headphone amp
Final updates to mine, updated to XU208, don't think this setup can get any better than what it is. (happy)
Soekris dam1021-12v2 dual-mono balanced: https://imgur.com/a/fD68M
Hypex nc400: https://imgur.com/iORCyna | Overkill TT2USB: https://imgur.com/a/p6OiS
Old 16th February 2017, 03:47 PM   #230
Default My TDA1541 dual dac pcb
This is my first attempt at a dac pcb. Its for use with Iancanada's I2S to pcm board shown next to it.
The dacs will be operating in simultaneous mode with true and inverted data, one dac per channel.
I will be testing it using 100r I/V resistors and a pair of Sowter bifilar wound i/v transformers.
Future plan is for an I/V pcb with four AD844 and four opamp buffer/drivers for the transformers, probably OPA627 or similar.
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Copyright 1999-2017 diyAudio
