DAC gallery
DAC gallery
Old 19th May 2010, 11:26 AM   #11
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
DAC gallery
You see here my new finished Reference DAC Project.
  • Custom made transformer on double C-Cores
  • +/- Power Supply Module with four voltage lines
  • Shunt regulator Modules for each voltage line (+5V, -5V, -15V, +5V)
  • TDA1541A NOS DAC Module with I2S input, DEM reclock circuit and I2S attenuator , cascadable !
  • Tube-I-zator output buffer Module
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 23rd May 2010, 01:56 AM   #12
stokessd is offline stokessd  United States
stokessd's Avatar
Here's my latest.
Sheldon
Old 28th May 2010, 08:00 PM   #13
1543 is offline 1543  Germany
1543's Avatar
DAC gallery
TwistedPearAudio Buffalo II Dac (ESS Sabre 9018)
Upgraded IVY III with Bulk Foils Resistors S102C from Texas Components
Old 28th May 2010, 08:09 PM   #14
poler is offline poler  United States
nice!!! did you make that chassis?
Old 28th May 2010, 09:05 PM   #15
1543's Avatar
DAC gallery
Thanks.
No, I do not have equipment to do CNC milling and engraving by myself.
The Alu-Profiles are from km-housings. Milling and engraving of the panels was done by Schaeffer-Apparatebau (Frontpanelexpress in US)
Old 31st May 2010, 04:40 PM   #16
sjalloq is offline sjalloq  United Kingdom
Send a message via MSN to sjalloq
1542 - 2 questions about your very nice case.
Where did you get the front panel knobs from? I'm finding it near impossible to find what I'm looking for.
And do you have any pictures of how you mounted the display? I'd like to do something similar but am unsure of the mechanics of fixing it to the front panel.
Thanks a lot.
Old 1st June 2010, 06:32 AM   #17
1543's Avatar
DAC gallery
I get the panel knobs form a ebay seller named hongkongsuperseller (Item# 120495984706)
For now there is no display assembled. I am still waiting for the controller / display announced by twistedpearaudio. What you see at the pictures is a piece of plexiglas with no display behind.
Old 1st June 2010, 08:00 PM   #18
apolon34 is offline apolon34  France
Send a message via ICQ to apolon34
Here is mine:
Old 10th June 2010, 09:42 PM   #19
Voegelchen is offline Voegelchen  Germany
Hi folks,
here are some pics of my almost 4 years old DIY DAC with PCM1796 and its measurements with AudioPrecision SYS-2. It uses ADAV803 as SRC and has a link input for my DSP Equalizer (also DIY, but not on my homepage yet :-(
Click the image to open in full size.http://www.ac-vogel.de/UltiDAC/UltiDAC.html
Old 8th July 2010, 10:55 PM   #20
martinbls is offline martinbls  Germany
My Scott Nixon USBDKII, based on the TDA1543.
Simple but very good sounding unregulated power supply, integrated volume control (Alps 20k), Sedlbauer toroid transformer 30VA, Wima output caps and the very important Sanyo Oscon for TDA1543 decoupling ;-)
I really like the sound of this dac! It's dynamic and fast, lively, coherent and natural sounding with a remarkably controlled and tight bottom end. Very open and forward, but without being excessive in any area.
But I tested MANY different power supply designs and different output coupling caps before I threw all this into the case...
DAC galleryHide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
