DAC gallery - Page 15 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th April 2014, 08:36 PM   #141
Default Pedja Discrete diamond I/V
Originally Posted by McGyver View Post
What I/V you write about? All DACs you mention are voltage out DACs and they need no I/V stage, frankly they works decently with no analogue stage at all, with one capacitor per channel alone.
My favourite to date is WM8804-PCM1794-passive I/V-tube gainstage DAC with Duelund CAST signal capacitors.
Rest of my setup are:
-EAD T-1000 CD transport (modified)
-Kondo KSL-M7 inspired handmade tube preamp
-modified ukrainian tube DHT PSE monoblocks based on 6B4G power triodes (excellent!)
-Merlin VSM Millenium speakers, but i'm working on to replace it by far better handmade ones.
As you can see, there is no single semiconductor in analogue signal path of my setup.
I use the Pedja discrete diamond I/V that is a bit similar to the AD844 on paper (current mirrors). I use that with the Philips TDA1541A S1 Crown. Yes, my voltage out dacs need no I/V and have none. The Saber might have an I/V however that OPPO player is unmodified. I am looking forward to trying the PCM1704 in the near future and possibly the PCM1794. Nice setup with all those valves. My builds for the most part have no negative feedback at least globally. I love the sound of tubes! Keep up the good work.
Old 29th April 2014, 12:44 AM   #142
danzup is offline danzup  Romania
danzup's Avatar
Originally Posted by Torchwood421 View Post
Nice... Which one is the favorite to your ears?
All TDA1541 are my fav. Everyone have their own sound.
There are not better tube than 6P3S and 6N2P for my ears !
Old 29th April 2014, 01:52 AM   #143
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
The DAC's a semiconductor and certainly has an analog stage. Besides which the internal digital processing has already added modulation noise. To have a purist approach (like your valve-based analog stages) you'd also want to minimize digital artifacts wouldn't you?
My latest DAC build is here - based on using hundreds of capacitors to implement passive shunts on the supplies. The DACs are TDA1387 (6 in a stack), passive I/V, Chebyshev LC filtering then the analog stages are AD815s, one per channel. There are hand-wound ferrite cored transformers in the base doing SE-unbal conversion. Battery power comes from 3 NiMH AA cells giving over 10hrs of listening.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 29th April 2014, 09:26 AM   #144
With all this talk about "Power DACs" nowadays, a "Tower DAC" is nice for a change!
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 3rd May 2014, 12:14 PM   #145
Tried TDA1541A-S1 also with good results in SQ.
AD1865 with CS5813 digital filter sounds very good, but replacing SM5813 with SM5842 gives significantly better SQ. Now it is comparable with my usual set PCM1796/CS8416. I'm rather settled with PCM1796 or 1794 as it reads HD formats and DSD also, so why bother with ancient chips?
Do You used in this compare, similar analogue tube output to this picture?
If I see properly, that power supply transformer is from LINN (it's linn logo?). Greetengs!
Old 5th May 2014, 03:20 PM   #146
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
A line pre-amp with built in DAC I made. still need to cut a top and program the micro-controller. has 3 coax and 2 fiber digital inputs (as well as 3 analog inputs) on the rear and one of each on the front. made the entire thing including the panels from scratch.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 5th May 2014, 03:46 PM   #147
Hello colleagues. From experience, it is desirable to apply the tube stage better options.
Old 28th May 2014, 07:01 AM   #148
Default Most recent DAC
Finally getting around to finishing some older projects. This one is a Sheldon Stokes 4398 DAC. Uses 8416 to sample rate convertor and outputs 192 KHz to a CS4398. Works well enough for my streaming and Bluray DTS -Master audio via Toslink. Lundahl transformer based filter for the output. Not on the same level as my 1541 based DAC's however it has it's place. I did install a Tent oscillator module and a dedicated clock power supply. The wood front is a piece of Brazilian Yellow heart with a simple finish. I have a Maple faceplate in the works when my wood working friend finds time.
Old 28th May 2014, 07:03 AM   #149
Default Another picture
Under the hood.
Old 28th May 2014, 07:05 AM   #150
Default Final picture
Back panel featuring Neutrik connectors. The mini toggle selects Toslink or coax SPDIF.
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 06:10 PM
Copyright 1999-2017 diyAudio
