DAC gallery
DAC gallery
Old 21st August 2013, 07:43 PM   #101
McGyver is offline McGyver  Poland
McGyver's Avatar
For windows a driver is needed. With proper driver it works very well and sound quality is very good to excellent. With MacOs it need no driver at all.
Old 8th September 2013, 10:26 AM   #102
florianderton is offline florianderton  Austria
Default Buffalo IIISE with Ian's FIFO and Luckit WaveIO
Just finished my DAC. As Luckit WaveIO supports two simultaneous outputs, SPDIF and IS, and Buffalo DAC supports to switch between two inputs, also SPDIF and IS, I managed to be able to switch between Buffalo onboard Clock (and SPDIF) - and Ian's FIFO Clock (and IS). Interesting comparison! Furthermore I realized to switch onboard clock between mains/ shunt regulator supply - and battery LiFePO4 supply, indeed an improvement with the latter. FIFO dual XO board is always fed with battery LiFePO4.
Old 21st September 2013, 11:44 AM   #103
grunf is offline grunf  Croatia
grunf's Avatar
my tube output DAC
Old 21st September 2013, 12:05 PM   #104
grunf's Avatar
added a double CCS for PMD100
DAC is based on the PMD100, the two PCM1702, two 6S4P-EV for I / V stage and two 6S4P-EV for the output buffer
Old 15th October 2013, 12:26 PM   #105
mksung is offline mksung  Taiwan
Default ElectrArt PCM2DSD and DSD principle board
Have Build PCM2DSD which convert PCM to DSD,and DSD signal pass 8TAP FIR filter to convert to analog. There are 4 74x574 cihp which could be cheaper than DAC。
1. DSD principle + PCM2DSD + UCC power
2.PCM2DSD
3.PCM2DSD + UDA
Old 11th January 2014, 09:13 PM   #106
Dimitris AR is offline Dimitris AR  Greece
My new Diy DAC with the CS8416 and the TDA1543 .
Old 15th January 2014, 10:19 AM   #107
ishiru is offline ishiru  Indonesia
my 2x TDA1545 + CS8414 DAC
there's X-Fi Surround Pro 5.1 i modded w/ linear PSU for USB input (the internal DAC was broken after my screwdriver accidentally shorted the VOut w/ its Vdd )
there's also an AZ1 and 12AT7 for the output
i forgot to remove my laptop in the 1st pic
you all makes me embarassed of my works.i'm crap on designing
Old 18th January 2014, 08:15 PM   #108
nopants is offline nopants  United States
looks nice, did you make those boards yourself? I have a bunch of copper clad but I wouldn't even know how to make something that looks remotely as good.
Old 2nd February 2014, 08:13 PM   #109
FEDOSOFF is offline FEDOSOFF  Russian Federation
Hi guys, I'm on the forum a few days. I want to share hot news. Photo on my DAC. His appearance is not impressive. But, it applied a new technical solution. Allowing chip RSM1794A, double as a voltage amplifier. For example, 0 dB - 20 volts at the output. The connection galvanic. This solution has been sought by the Eurasian Patent Office. 201300368 priority number from 08 - 04 - 2013. Examination has already been passed. Analogues prejudicial solutions found. In the summer I'll introduce you with this technical solution. In the meantime, I would like to discuss with you the prospects for this DAC.
Old 22nd February 2014, 10:56 AM   #110
ROCKMANDRAKE is offline ROCKMANDRAKE  France
DDDAC under construction.
I am waiting for 1794S mainboard in order to finalize this design...
Rock
DAC galleryHide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
