Confusion on home made buffer, one channel clear, two channel not?
Old 14th May 2010, 12:49 AM   #11
Destroyer OS is offline Destroyer OS
Destroyer OS's Avatar
I get a lot of noise if I touch the inputs on the JFET's.
Old 14th May 2010, 01:53 AM   #12
If I so much as plug in the power cord with the amp on I get noise. I got no idea why. That is with the power off.
I have no idea what is wrong, I give up. I am just going to have to wait who knows how much time and get a PASS B1 I guess.
Old 14th May 2010, 09:39 AM   #13
robertor is offline robertor  Hungary
robertor's Avatar
the lm317 is only for the positive supply.
the output will be xx volt/0 volt or GND.
rob
Old 14th May 2010, 11:42 AM   #14
Joris is offline Joris  Netherlands
Joris's Avatar
robertor, I disagree with you, it IS possible to create a positive and a negative voltage with 2 pieces of LM317. It would be nicer to use LM337 instead, but it should work without trouble.
I think since it is a shared power supply for both channels, the problem isn't in the power supply, it must be in that left channel. You should check the circuit board for bad ground connections.
You could also try to swap the amp inputs, so left channel becomes the right and the right becomes the left, this eliminates any doubts about the amp itself.
Could you post me a picture? So I have a clue what we're talking about exactly..
Best regards
Old 14th May 2010, 11:45 AM   #15
Joris's Avatar
If I understand it correctly, you get noise when you plug in the power cord of the amp that is connected to your circuit? If that's true, you certainly have a ground loop.
Old 14th May 2010, 04:00 PM   #16
Yeah well I put the whole thing into the closet until I need the box again... I can not even imagine how a ground loop was being created without the circuit even on.
Old 14th May 2010, 08:27 PM   #17
robertor's Avatar
re-build the power supply with 317/337 and try another time.
don't work fine?
search for another problem.
must to go for exclusion: that work fine and the problem persist? check the fet or buy some j-fet buffer PCB come from china.
jims-audio have the borbely.
p.s.: i'm not able to build a power supply work fine then i buy from some Chinese ebay seller. the price is absolutely absurd and make their work.
rob
Confusion on home made buffer, one channel clear, two channel not?Hide this!Advertise here!
5.1 Channel Chip Amp/Gainclone for Home Theater Buddie Chip Amps 117 22nd February 2011 02:01 PM
Tangent's ground channel w/o buffer morfic Solid State 17 2nd August 2009 05:20 AM
home theater with 2 channel preamp bonsai171 Solid State 1 3rd June 2006 12:28 PM
1 channel not clear hipyo Car Audio 13 25th August 2005 05:12 AM
6 Channel Home-theatre chip amp 6*50Watt Douchekop Chip Amps 2 14th September 2003 05:12 PM
Copyright ©1999-2017 diyAudio
