| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hello together
I want to substitute OPA output-stage of my CDP by transformers, do you have any experience? DACs are AD 1862 (1mA, 2.1kOhms) I tried one of 200:200 Ohms but low frequencies are weak. 600:600 is better but not perfect. Can anybody give some advise? CDP is Denon DCD 2560. Thank you kabee |
#2 |
is choosing a less facetious title...
I suggest getting some lowish value trimpots and putting them from each leg to ground and trim till you find the right loading, then you can either substitute them with set value high quality resistors, or get a transformer that matches that impedance
#3 |
Thank you I will try
#4 | |
RIP
#5 |
Thank you Bill.
Do you recommend step up or step down? Volume is same like OP-Amp with 1:1 tranformer now. |
#6 |
RIP
Step up, similar to MC trafos. Please try the Lundahl, and Sowter websites. GOOGLE is your friend.
Sure, it works now, but what does it sound like. I've been using 1/1 trafos with Vout dacs but this is different, unless the 1862 is a special case that I'm not aware of. Maybe someone with direct experience with the 1862 will chime in. |
| Question: schematics of the analogue output circuit available? | Franz Gysi | miniDSP | 4 | 18th April 2010 07:22 AM |
| Marantz CD63 MkII KI analogue/digital output | canetoad | Digital Source | 5 | 8th September 2009 12:14 PM |
| Analogue output stage | maxpou | Digital Line Level | 0 | 18th April 2009 02:48 PM |
| Useful power transformer design thread on Analogue | kevinkr | Tubes / Valves | 1 | 23rd November 2008 02:23 AM |
| Samsung BD-UP5000 Analogue Output | vizion | Digital Source | 0 | 17th January 2008 05:33 PM |
