Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th May 2010, 10:04 PM   #1
Default Pink Triangle Ordinal repair
I have just received an Ordinal through the post. Unfortunately it rattled when I picked up the box. On investigation, I found that one of the three transformers in it (the one at the back near the IEC socket) had come loose from the PCB, snapping the thin wires coming from the coil and attaching to the mounting pins on the PCB.
I can't see any obvious damage to the PCB or other components mounted on it, nor can I see any signs of leaking/bulging capacitors, so that is does not appear to be an issue (yet!)
Does anyone know if this sort of problem is easily repairable, and if so, who can do it. I live between Peterborough and Cambridge, and work in central London if that helps.
The third alternative is returning for a refund, if repairs would cost more than the unit is worth
Any advice gratefully received; I'm more of an analogue PT guy, but I thought I should try some of their digital work whilst I could.
-- Tim
Old 7th May 2010, 06:23 PM   #2
Send a message via MSN to sq225917
Tim, throw a picture up if you can and scribble down the serial from the transformer if possible. Worst case, if nothing else is damaged is that you are looking at £20 ish for a new traffo.
I'd be happy to take a look at the damage via pictures and give you advice going forward, if it's doable and you can find a suitable part I'd be happy to do it for nothing if you can get it to Sheffield.
simonatwork@hotmail . com
hoping to pick up some things.
Old 7th May 2010, 11:16 PM   #3
Thanks for your kind offer, I have posted you some photos; the only markings appear to be
(MD) [manufacturer logo]
LEICESTER
ENGLAND
E142x14.8mm B
cheers,
Tim
Pink Triangle THE PIP lohk Solid State 26 31st October 2011 11:50 AM
Repair of Pink Triangle Da Capo DAC William C Digital Source 17 11th January 2010 09:43 AM
Pink Triangle LPT avinunca Analogue Source 5 18th March 2009 11:20 AM
Pink Triangle Da Capo Repair RichardDickinso Digital Source 3 21st January 2008 07:47 PM
Pink Triangle questions fernando Analogue Source 1 15th February 2005 08:59 PM
Page generated in 0.08157 seconds (67.13% PHP - 32.87% MySQL) with 10 queries
