2x TDA1541. noise quesion
Old 15th May 2010, 09:58 AM   #21
Joris is offline Joris  Netherlands
Joris's Avatar
Hi Nick,
It could work, but both the capacitors are needed.
I've had mine connected just like this, only with 2 caps.
First try without the link, you can always try to connect them later, it slightly betters the sound.
Best regards
Old 15th May 2010, 11:08 AM   #22
ecdesigns is offline ecdesigns  Netherlands
Why would he make it like this in the first place? Can it work as is?
He made it like this in an attempt to synchronize both DEM oscillators.
I am pretty sure it cannot work like this. The solution Joris suggested might work but reliable operation cannot be guaranteed (oscillator drift / component tolerances).
My advice, cut the interlink between the chips and use two separate 470pF caps. I am quite sure the noise problem will be solved then.
Old 15th May 2010, 11:29 AM   #23
Nick122147 is offline Nick122147  China
How can I do this? I think I found the traces on the upside of the board. How do I cut them without making too much damage to the surroundings ?
Old 15th May 2010, 01:45 PM   #24
The traces on the PCB can be interrupted using a 1mm PCB drill. Drill in the center of the PCB trace. This causes minimum damage to the PCB. You have to interrupt the trace as close to each IC as possible so the remaining piece of PCB trace won't pick up interference.
If you don't mind soldering at the TDA1541A pins you could try to carefully bend pins 16 and 17 so they are outside the IC socket. Then solder a small 470pF cap (1206 NPO SMD cap for example) directly between pins 16 and 17 of each DAC chip. This way you don't have to damage the PCB.
Old 15th May 2010, 02:47 PM   #25
Thanks, this seems doable. If I decide to try to bend the legs on the dac, would it be enough to do it with the one dac that hasn't got the cap now?
Old 15th May 2010, 03:13 PM   #26
I just started thinking: The DAC was still noisy when running with just the right 1541 (the one with the cap in place). Shouldn't it have been quiet then when not connected to the dac if the other capless dac is the problem ?
Old 16th May 2010, 07:05 AM   #27
Joris's Avatar
That could be, but there are still lines attached to the cap, so remove those connections to the other TDA first. When those lines are gone it should be OK.
Old 17th May 2010, 01:20 PM   #28
I received two 470 pF caps today, and bent the 1541 legs outside the socket (on both 1541's) and soldered them to leg 16 and 17.
No difference!
Still the dac is very noisy at low volume. Also when comparing to the cheap cs4398 dac, the highs are almost none excisting. The bass seems good, but the sound is clearly not good.
This dac should‘t be noisy even at not full digital volume should it? In quiet music I can hear the noise even at full volume, but at 10% volume the noise is very loud. At 60% volume it is annoying.
Old 17th May 2010, 05:47 PM   #29
Joris's Avatar
Hi Nick,
That's strange, this means that the DEM clock (it's an internal DAC clock) is running normally, or that both your TDA's are fried. I schould consider asking the seller for a replacement unit. This DAC shouldn't produce any noise, not even at low volumes...
Best regards
Old 17th May 2010, 06:56 PM   #30
flancfuster is offline flancfuster  Romania
No difference!
Hi Nick,
I had problems with noise(artifacts like) on my 4XTda1541A (similar schematic to yours). After many hours of testing I've found out that one of the voltage regulator was not working properly , even though when voltages were checked the readings were in order. (when I slightly move the regulator, the voltage dropped suddenly). You should try to check the power supply.
Good Luck,
Sorin
Ps. I've got better results using tubes for I/V stage.
2x TDA1541. noise quesionHide this!Advertise here!
TDA1541 - noise in one channel? phofman Digital Source 6 17th October 2016 10:57 AM
A quesion about ORCAD part lib????? roberd Chip Amps 4 30th May 2006 06:22 AM
noise problem with TDA1541 vincent_brient Digital Source 16 14th March 2005 08:58 PM
Naive CCS quesion zobsky Tubes / Valves 5 6th August 2004 11:50 PM
flickering noise at silent passages (CS8412+TDA1541) weissi Digital Source 4 17th May 2003 12:16 AM
