| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I suffer audio dropouts ever few seconds in mine Buffalo II. The frequency of the dropouts often decreases the longer the unit is used. I suffered the same problem using the USB or SPDIF digital input. Possible will be due to noise on the SPDIF/I2S ground, how can solve the problem?
#2 |
Can you describe the rest of the audio chain? How are you powering the dac?
www.hifiduino.wordpress.com |
#3 |
Sony Vaio, hi-Face 24/192, Buffalo II DAC , Borbely balanced lineamp, Borbely 75 W RMS class A mono power amps, Wilson Audio speakers.
I am powering the DAC with Salas V1.0 regulator with remote sensing, Tx R-Core 9V 30VA. Now DAC is going with passive I/V resistor 200 ohms + 4.7uF decoupling cap in each phase. Last edited by merlin el mago; 1st May 2010 at 06:15 PM. |
#4 |
Is your salas regulator ground connections connected to any ground or floating? Typically, the PS to the DAC is floating, the digital ground connects to the gnd of the source and the analog gnd connects to the preamp/amp.
#5 |
Thanks for the answer. Mine Salas reg. ground is connected only in the ground to power the DAC, isn't connected to chassis, the analog output gnd is connected to pre-amp/amp gnd & the digital ground connects to the gnd of the source.
#6 |
What's the current of the shunt supplying VD?
Most of the times these issues are linked to insufficient current on VD. Last edited by TheShaman; 1st May 2010 at 11:41 PM. |
#7 |
I have experienced the problem also on other DACs when playing from PC / Mac..
On the Mac there was a "bug" and leaving one specific program open solved the most of the dropout problem.. Playing over ethernet was causing more problems, and playing over a wireless link even worse... When I started to evaluate iTunes, Foobar, XXhighend, J.River etc.. I found that they all sounded different from the same sources - and non of them sounded good. I ended up with using iTunes as the library and a SD card player as a superior solution in respect of audio quality with ZERO dropouts and constant good audio quality..
Mac OS X / Linux, Isolated Hi-Speed (480Mbps) (with automatic LSB extension correction to 32bit for True BitPerfect) USB 2.0 -> I2S (352.8k/384k/32bit) / DSD, JFET powered ES9018 DAC, JFET class A / DSD poweramps, AMT fullrange speakers |
#8 |
#9 |
5.5v ?
My 32S is powered by a 350mA Placid and fed by an M2Tech as well, but I've never experienced such issues. :S Last edited by TheShaman; 2nd May 2010 at 11:05 AM. |
#10 |
Yes 5.5V, do you know If I can solve the problem adding the Twisted Pear S/PDIF Receiver Module?
| Buffalo II | Russ White | Twisted Pear | 1772 | Yesterday 10:00 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| I2S ground noise issues & possible resolutions | jkeny | Digital Source | 21 | 27th February 2010 05:22 PM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| USB audio codec with SPDIF or I2S out | bocka | Digital Source | 9 | 15th June 2005 08:31 AM |
| Page generated in 0.09554 seconds (79.33% PHP - 20.67% MySQL) with 10 queries |
