| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
I have been asking the same question about the CS8420 with no avail because I use a DCX2496 or M-Audio Firewire 410 for active cross. Apparently Cirrus never made a more modern drop in replacement for it despite a legal battle over it's problems which prompted Behringer to pull production of the DCX2496 for a year despite huge demand. The only solution for replacing the CS8420 that I have read about is the Oettle clock board from Pilgham Audio although it would be cheaper to sell your dac and buy a Big Dac Board from Ebay which can be ordered with DIR9001, CS8421 and CS4397.
. Pilgham Audio - SRC/Clock . The CS4397 is still one of the best sounding dac chips. Reportedly better than 4398 or PCM1798. It is at it's best when playing direct out through transformers or a blocking cap with no active stages. There is a long thread about the Big Dac Board here. . Experience with this DIY DAC ? .
Scott |
#12 |
This is a bit old but.. is there any more info on swapping the CS8420 for CS8416?
For example, if one were to swap the CS8420 for CS8416 and swap the AK5393 for AK5394 ADC on a Behrigner SRC249, would it then be able to handle 192KHz? |
| Cirrus Logic CS4397 DAC KIT | acccruz | Digital Source | 5 | 1st December 2009 11:55 PM |
| Chinese DAC in a Box: CS8416 / CS4397 | Franz G | Digital Line Level | 92 | 16th April 2009 01:18 AM |
| dac pcm1794 vs cs4397 | evert1 | Digital Source | 2 | 19th October 2008 02:36 PM |
| need help for UPGRADE CS4397 DAC DIY KIT | nickthevoice | Digital Source | 1 | 3rd May 2008 09:32 PM |
| CS8420 and CS4397 question | macsaif | Digital Source | 0 | 16th January 2003 06:57 AM |
