Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th April 2010, 04:04 AM   #1
phrarod is offline phrarod  United States
Default Need ground advice on a DAC with tube output
I had someone put my dac into two chassis and I still get a decent amount of hum. I went through the grounding scheme and made an illustration.
My questions are:
All the digital and the analog grounds are star grounded to one point in the Dac Box. I want to separate the digital grounds from the analog grounds.
I could float the B- for tube circuit including Fil supply in the Dac box. Since the DAC box is sharing chassis ground with the PS Box I'm not sure how to separate them.
I could separate them and float both star grounds of digital and analog above ground at separate points.
Also I want to get the filament supply as quiet as possible. In the past I would make pseudo center tap with 2 100 Ohm resistors and tap the middle to B-. Not sure the best way to do it when one is in another box.
I should also add that in addition to the dac board in the dac box it has its own separate power supplies - two (one bi-polar) for a total of three supplies being run by two torodial transformers coming off their own power cord. The torodials are shielded with mu-metal from the supplies which in turn are shielded by a grounded shield from the dac board and the analog stage.
Old 27th April 2010, 05:58 AM   #2
Is the hum only with chassis or every time
what uF you are using to filtrate B+
I had hum when I got 47 uF / 450 V as a first cap and 100 uF / 450 as a second
when I replace them with 330 uF / 450 V as a first and 220 uF / 450 as a second I got rid of hum
Old 27th April 2010, 06:02 AM   #3
Hum is consistant. The last caps are 33uF/400V. Before those are 47uF/400V and before those several chokes and before the chokes are EZ81 tubes.
Advice needed: Output stage in Sony TA-E9000ES (CXA8042AS DAC) Groundloops Digital Source 2 22nd June 2011 03:20 AM
DIY tube output in DAC - needs advice... jazzpeter65 Digital Source 71 3rd April 2011 04:46 AM
My new tube DAC output Algar_emi Tubes / Valves 46 19th January 2011 05:57 AM
Tube output buffer for DAC....needs advice! jazzpeter65 Tubes / Valves 0 4th April 2004 10:48 AM
tube cd output advice Raj1 Tubes / Valves 18 4th October 2003 07:57 PM
Page generated in 0.07421 seconds (67.24% PHP - 32.76% MySQL) with 11 queries
