| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#41 | |
Even with unshielded interconnects to power amplifier. And even with the bad grounding. |
#42 | |
#43 |
Yeah. This scheme is really working and working really well.
I prefer it to TDA1541. Its also very easy to build on stripboard. I have never used CS8416 So cant say if it works or not without trawling through datasheets.
If you give up easily Dont start!! |
#44 |
CS8416 has :
24-bit, left-justified 24-bit, I2S 24-bit, right-justified Direct AES3 PCM56p is :EIAJ STC-007-COMPATIBLE Hm that does not show what kind of parallel interface is using PCM56p?
www.kondenzatori.com - Магазин за продажба на кондензатори. |
#45 |
Hi, PCM56P is using serial interface. Check page no. 7 of the datasheet for waveforms. Should be farely easy to obtain from I2S. I will give this thinggy a try as soon as I get the chance and will let you know of the results.
| Output Current from PCM56P K? | georgehifi | Digital Line Level | 30 | 16th May 2009 07:50 PM |
| WTB pair PCM56P S-grade DAC chips | reaction | Swap Meet | 0 | 12th March 2008 07:35 PM |
| worth replacing the pcm56p-k in an old cd player? | badbrother | Digital Source | 3 | 8th September 2007 08:17 AM |
| Can single PCM56P act as stereo? | terranigma | Digital Source | 1 | 27th February 2007 09:29 PM |
| Page generated in 0.08689 seconds (71.04% PHP - 28.96% MySQL) with 11 queries |
