cs8416 + pcm56p
cs8416 + pcm56p
Old 8th November 2010, 10:12 PM   #21
rfbrw is offline rfbrw
Not with a single chip. Both channels share a common serial clock input.
Old 9th November 2010, 10:58 AM   #22
regal is offline regal  United States
Originally Posted by QSerraTico_Tico View Post
It's to keep the clocks synchronously. The clock for the lower DAC is stopped certain periods of the Latch, hence the name "stopped clock" method.
Anyway the method with simply inverting the latch for 1 channel sounded slightly better. This was tried with the AD1865 though.
74HC08 is an AND gate, doesn't make sense that the signal and +5vDC are being input into the gate?
Old 9th November 2010, 11:49 AM   #23
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
Cool Smart?
Yes with two chips AD1865 (balanced DAC) or two AD1851.
Old 9th November 2010, 02:26 PM   #24
Default Not cool enough ?
A real audiophile would have milled off the top of the AD1865 and separated the two channels for a truly valid comparison.
Old 9th November 2010, 06:52 PM   #25
Old 9th November 2010, 11:51 PM   #26
I2s to AD1856, I think will work for PCM56, see attached.
Old 11th January 2011, 10:31 AM   #27
hotiron is offline hotiron  Scotland
hotiron's Avatar
Default Eureka
Guys I've been messing with this for a while now and could never get it to work
(single inverter) I was was getting a lot of noise in the non inverted channel.
However after some more fiddling last night I had success ,initial listening sounds promising
I'm using CS8414 74VHC04 PCM56P
See schema below.
If you give up easily Dont start!!
Old 11th January 2011, 12:29 PM   #28
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
You can get problems just from the layout of data and clock wires.
Best use passive I/V and analog filter.
Old 11th January 2011, 09:23 PM   #29
hotiron's Avatar
Bernhard you have my utmost attention and respect but what do you mean exactly by problems with timing? This sounds awesome the way it is, eg no TDA and no op amps ,
PS data and clock wires are less than 15mm.
Old 11th January 2011, 09:57 PM   #30
hotiron's Avatar
Default Mr Clean
This was my best DAC.
cs8416 + pcm56pHide this!Advertise here!
Output Current from PCM56P K? georgehifi Digital Line Level 30 16th May 2009 07:50 PM
WTB pair PCM56P S-grade DAC chips reaction Swap Meet 0 12th March 2008 07:35 PM
worth replacing the pcm56p-k in an old cd player? badbrother Digital Source 3 8th September 2007 08:17 AM
Can single PCM56P act as stereo? terranigma Digital Source 1 27th February 2007 09:29 PM
