Capacitorless PSU
Capacitorless PSU
Old 26th April 2010, 01:10 PM   #31
Nazar_lv is offline Nazar_lv  Europe
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
OFF hm, i cant delete, there is no button, what i am doing wrong?
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) S-Audio.Systems
Old 22nd October 2011, 04:41 PM   #32
rha61 is offline rha61  France
I'm currently testing your "electronic cap " PSU on a AK4396 DAC
It sound really very good
Thanks Nazar
Old 23rd October 2011, 09:55 AM   #33
Nazar_lv's Avatar
you’re welcome!
Old 9th January 2013, 07:53 PM   #34
Milos P. is offline Milos P.  Serbia
Hi Nazar,
I'm building your PSU for my RIAA phono (LME49990 in, passive RIAA, LME49713 out). I have 100n from the schematic (output caps) very close to my
power in pins on the 49713 but not as close for the 49990.
I was wondering, do I still need local bypass caps? I was thinking of 4.7uF MKP parallel to 100n NPO, from each rail to GND.
Thank you
Old 11th January 2013, 09:25 AM   #35
Nazar_lv's Avatar
Hi Milos, use 0.1NP0 between + and -, and 1-4.7u MKP from +,- to ground (not necessarily, use you ears to determine what is best).
Old 11th January 2013, 09:47 AM   #36
Nazar,
thank you. Any drawbacks for using R1-R9 47ohm and C3-C7 470uF?
I have +/- 23V after the rectifier and I need +/-15V (@~20mA).
Old 8th February 2013, 08:38 AM   #37
Nazar_lv's Avatar
no problem, but 317/337 need input voltage min=output voltage+2..3V
And line volrage instability (180-242V)
Old 10th February 2013, 12:57 PM   #38
Thanks.
Old 11th February 2013, 01:05 PM   #39
marce is offline marce  United Kingdom
Capacitorless PSU
SUPPLY BYPASSING
To achieve a low noise and high-speed audio performance, power supply bypassing is extremely important.
Applying multiple bypass capacitors is highly recommended. From experiment results, a 10μF tantalum, 2.2μF
ceramic, and a 0.47μF ceramic work well. All bypass capacitors leads should be very short. The ground leads of
capacitors should also be separated to reduce the inductance to ground. To obtain the best result, a large
ground plane layout technique is recommended and it was applied in the LME49990 evaluation board.
Most op-amp manufacturers produce a guideline and app notes for decoupling, use engineering not your ears (they tell you nothing about decoupling), this is more critical these days because of the amount of RF and other high frequency noise present in the envoironment.
Old 12th February 2013, 08:03 AM   #40
Nazar_lv's Avatar
our ears perfectly hear result of good decoupling etc (and of good PCB tracing, low EMI, etc etc etc)
Capacitorless PSUHide this!Advertise here!
Quieting a Switching PSU? or easier to replace it with a linear PSU? at77 Power Supplies 23 18th March 2010 05:46 AM
capacitorless or shunt PS in PP output stage? AudioGeek Power Supplies 2 9th November 2009 11:21 PM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 10:45 PM
Capacitorless line-level XO? Nixie Multi-Way 1 13th August 2006 10:05 AM
pre-PSU for cuno snoeren XO PSU? pukka Digital Source 0 30th December 2003 02:39 PM
