Capacitorless PSU
Capacitorless PSU
Old 20th April 2010, 07:28 PM   #11
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Nazar_lv View Post
he-he 0.2ohm resistor with 15v regulator
?? If I read the circuit correct, the transistor shunt takes about 2mA from the 15V (if it is 15V). A 7.5k resistor does the same.
jd
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 20th April 2010, 08:16 PM   #12
Nazar_lv is offline Nazar_lv  Europe
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
not correct. Remember Ohm's law at least. And there is formulas to calculate properly.
And output impedance of this circuit is 0.1-0.2ohm
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) S-Audio.Systems
Old 20th April 2010, 09:03 PM   #13
diy_audio_fo is offline diy_audio_fo  Italy
In this web page:
PSU for High end audio without electrolytic capacitors - English - Black Gate capacitors Cerafine Electrolytic electronic capacitor Nichicon power supply Pureism Silmic - Nazar audio innovations
I read:
R2=(1,25-Ueb) / (0.3/Uout)+Iload
where Uout-output voltage V, Ueb-emitter-base voltage VT1, VT4 V, Iload- load current А.
A resistor usually has dimension in Ohm
In the above formula which is the R2 dimension?
R2 = V / (A/V) + A has not Ohm dimension (Ohm = V / A)
What is 0.3?
And which is 0.3 dimension?
Old 20th April 2010, 09:27 PM   #14
jan.didden's Avatar
Yes you're right, it depends on R2 doesn't it. The 2mA is for the first transistor. What's the value of R2?
Did you check the output Z of the circuit without the shunt, just the 317?
According to the data sheet, it's 0.02 ohms up to 10kHz.
jd
Old 20th April 2010, 10:43 PM   #15
SoNic_real_one is offline SoNic_real_one  United States
Really? Then show me the same.
I don't want to get into arguments, I apreciate your work, but I think you didn't invented the shunt-regulated PS. Or capacitance multiplication filtration schematics. I saw those first time in '80's when i started playing with electronic schematics ( I think even "Radio" had a few published - if you are old enough to remember).
Capacitance multiplier - Wikipedia, the free encyclopedia
Old 21st April 2010, 12:48 AM   #16
wwenze is offline wwenze  Singapore
Recoiless rifle means recoil-less:
YouTube - Recoiless rifle
Capacitorless...
Old 21st April 2010, 07:27 AM   #17
jan.didden's Avatar
Looking again at the circuit, the shunt transistor is a small signal type with probably 600mW max dissipation. For say 500mW at 15V, that puts the shunt current at around 33mA, plus 2mA for the first transistor so say 35mA total.
The voltage across R3 is 1.2V, so across R2 we have 0.6V at 35mA so ballpark figure for R2 would be some 170 ohms.
Does that look sensible?
jd
Old 21st April 2010, 12:09 PM   #18
Nazar_lv's Avatar
Ohm
R2 = V / (P/V)+A
What is 0.3?
Max Power dissipation of 547\557 (at 70-80 amb/ temp)
yes, he has (as any NFB regulator) inductive output impedance, that is output current dependent (as output noise)
Its not a shunt type regulator and dont have cap. multiplication, look carefully.
Advantages of this schematic is
-no electrolitycs and it problems
-low and stable(resistive) output impedance
-Perfect transient response (Series regulator(317\337) is completely detached from load)
-High ripple rejection and low noise
-No dependence noise-output current, output impedance-output current
-no global nfb
Disadvantages
-Efficiency
Ohm's law R=U\I ... 17ohms
Old 21st April 2010, 01:59 PM   #19
Ohm
Ohm
R2 = V / (P/V)+A
R2= V / (P/V)+A = V / ((V * A) / V) + A = V / A + A has not Ohm dimension
perhaps you mean
R2= V / ((P/V)+A) = V / (((V * A) / V) + A) = V / (A + A) = V / A which has Ohm dimension
Old 21st April 2010, 04:03 PM   #20
Nazar_lv's Avatar
perhaps you mean
yes
thanks, i will fix it
Capacitorless PSUHide this!Advertise here!
Quieting a Switching PSU? or easier to replace it with a linear PSU? at77 Power Supplies 23 18th March 2010 05:46 AM
capacitorless or shunt PS in PP output stage? AudioGeek Power Supplies 2 9th November 2009 11:21 PM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 10:45 PM
Capacitorless line-level XO? Nixie Multi-Way 1 13th August 2006 10:05 AM
pre-PSU for cuno snoeren XO PSU? pukka Digital Source 0 30th December 2003 02:39 PM
