| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | |
In the car audio world, Audiocontrol made an analog 2 channel processor that I believe is fairly close to this concept (stereo widening). It was called an ESP-2. They also had an ESP-3 that added a center channel which would not be needed. This was a long time ago. The patent was issued to someone who later started SRS labs if memory serves me right. Here are a couple places to start: http://www.google.com/patents/about?...J&dq=4,748,669 http://www.google.com/patents/about?...J&dq=5,892,830 Last edited by durwood; 29th April 2010 at 05:52 PM. |
#22 |
I own a Hughes Sound Retrieval box that´s probably similar in concept to those patents. What they do is different to this.They are not recursive ambiophonics crosstalk cancellation. In RACE the added cancelling signals are have to be cancelled themselves ad infinitum so to speak. Hence the [I]recursive[I]. I figure that would take a fairly large number of opamps to achieve. For some reason it has never been implemented in the past until software power has increased exponentially.
#23 |
#24 | |
Bummer, it shouldn't be that difficult to implement but they probably have other priorities...maybe if or when it's slower for them.
electro-music.com :: View topic - Mosc's Ambio VST and with the newest version give you more degrees of adjustment for matching your tastes, including recursion. electro-music.com :: View topic - AmbiophonicDSP VST Plugin Now Available -but to each their own. You can also experiment with varying levels of recursion with the crosstalk cancelation plugin on this page. Christian’s Blog Spacial Plugins All of these can be used with foobar or winamp player by loading it into the VST-bridge plugin for each player. You might even be able to use line-in to pass 2 channel audio through the winamp player. |
#25 | |
don't have to do with the current filters. But the more people request it the greater chance someone will make it. |
#26 |
Let´s see if anybody can shed some light on this: I´m running a digital path from cd to laptop to my yamaha AX1 which does the DA conversion. As the volume knob is turned up higher-but within my usual listening level-a noticeable and annoying hiss is present in the tweeters from my listening position.
The culprit is either the computer or the edirol ua-1d adapters. It dissapears when virtual audio cable´s output device repeater is stopped, returns when started. The ambiophonic transcoder aplication makes no difference in this regard, since bypassing it or closing the application has no effect on it. I have searched the net but found no mention of the issue of hiss in a purely digital chain. All usb/spdif adapter reviews contain the usual audiophile ¨stage width- realism-musicality¨ nonsense but no mention of hiss. Anybody? I will start a new thread if there is no input here. |
| Need cheap optical input preamp/processor | proto5 | Digital Line Level | 2 | 9th June 2010 09:24 PM |
| DIY DTS/DD processor? | ezkcdude | Digital Source | 5 | 9th December 2006 02:39 AM |
| DIY Audio Effects Processor Books? | orson198305 | Everything Else | 2 | 10th June 2006 08:43 AM |
| DIY Surround Processor | Bane2871 | Digital Source | 5 | 16th December 2005 05:52 PM |
| cheap 5.1 processor | serosmaness | Everything Else | 1 | 3rd February 2004 01:11 AM |
| Page generated in 0.10565 seconds (77.38% PHP - 22.62% MySQL) with 10 queries |
