| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 |
LM49720 and LM4562 are exactly the same parts (just a new name) so you can not hear any differences!
![]() Another question: does the 24Bit/192kHz mode work? the old version had a failure with that mode! |
#22 |
the lampucera twentyten arrived today.
just changed the op amp with the TLE2026. i find it sound well, very well. spaciousness, articulated bass, and with the new opamp more sweet than the NE5532. ok, now i little running in. szia!
rob |
#23 |
i'd like o change the third opamp with the OPA627.
think it will be possible?
rob |
#24 |
Hi Rob
could you please test the 24bit/192kHz mode? Btw what is TLE2026? Datasheet? |
#25 |
hi tolu,
i don't know the way to test for 24/196. i know the cs8416 "has born" to work 24/196. the tle2026? sorry for my BIG mistake, i use 2 tle2062 and the third a tle2082.TI excalibur: Precision Amplifier - High Output Current - TLE2062 - TI.com somebody have tried some modding?
rob |
#26 | |
![]() 2) 24Bit/96kHz & 24Bit/192kHz flacs both playing beautifully... oy, now i gotta start a silent PC project as i don't have another high bit-rate source! I'll probably spring for a juli@ s/pdif upgrade while i'm at it (unless someone can suggest a good/fast/cheap better solution. this whole hobby is really getting to be a problem |
#27 |
but really you have some files 24/192?
rob |
#28 |
You can get some free and legal 24/192 flac here :
High Resolution Music DOWNLOAD services About my passive output project, I got my LL1636 transformers, I'm still waiting for some parts (resistors, box, wires...) I'll report back when I'll manage to get all of this running together! |
#29 |
me too i'd like use the transformers like output but, i think in my big ignorance, without schematic........... nothing to do.
the first thing for a dramatic improvment would be to replace, if there are, the output capacitors. usually are elko or worse. better will be replace it with film capacitors(polypropilene?). i ask for the schematic to the seller but not news yet arrived.
rob |
#30 |
I got the schematics with the DAC, but it is barely readable.
I asked an electronic version to the seller, but no luck... I dont' think there are output capacitors. For the transformers, I took inspiration from this passive output from Rakk : Passive output But he is using a PCM1794 where our dac uses a PCM1798. Smaller output current, so I went to the LL1636 transformer which can be wired as 1+1:10 to get a higher output level. And some 15Kohm resistors for I/V conversion. I'll give feedback as soon as I have all the remaining pieces. |
| DIY tube/phono pre in the same case as my DIY dac? | ben62670 | Analogue Source | 3 | 29th October 2010 08:46 AM |
| Do you have a Gigawork DAC? Is this a mistake? | ciagon | Digital Source | 4 | 8th March 2010 04:29 AM |
| Any experience with this ebay-dac-kit?(searching a diy-dac) | xTr3Me | Digital Line Level | 2 | 31st December 2009 11:07 AM |
| Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! | Jambo | Digital Source | 8 | 20th August 2008 09:41 AM |
| my very small DAC,24bit/192khz | leesan | Digital Source | 0 | 8th May 2006 08:08 AM |
| Page generated in 0.11655 seconds (78.92% PHP - 21.08% MySQL) with 11 queries |
