New Small DIY Gigawork Dac?
Old 4th May 2012, 07:33 PM   #251
charly chile is offline charly chile  Chile
Hi northernsky,
I think i am having the sane issue.
I removed the multiplexer mute chip.
I Also added the four 470 ohms to reduce output voltage.
I realized one of my amps didn't work.
So I tried a little SEP amp with capacitors at it's inputs and it sounded well.
So I am guessing I have the same DC problem.
Now I am adding 2 PIO .33 UF caps to test with my main amp and see how it goes.
Even with this work arround, there should be a cleaner way of fixing this issue?
I am afraid of those bypass caps ruining the sound..
Old 4th May 2012, 08:13 PM   #252
Listening to the new setup now.
It sounds well, distortion seems to have dissapered.
I don't have a pre, just volume on a Mac.
My speakers are super sensitive so I guess I will adjust again those opamp resistors to reduce opamp gain a little more.
What makes me happy about this setup is that I am not noticing a high frequency roll-off as when using a potentiometer before the power amp Push Pull el84.
Old 5th May 2012, 02:31 PM   #253
But even when my system performace has improved
Is a coupling CAP between dac and power ideal?
I guess, a less component approach is aleŠis better when possible.
Ideas to remove opamp stage bias:
1) test upgrade opamp power supply?
2) matching resistors in opamp section?
3) or just use a very boutique cap ?
Old 3rd August 2012, 02:36 AM   #254
prezden is offline prezden  Canada
I am looking to buy a GigaWork DAC but can't any place that sells them. Can anyone steer me in the right direction.
Old 13th April 2013, 01:04 PM   #255
Astaro is offline Astaro
So, somebody decided to problem of noise in pauses, after shorting mutes (short cut the 4056) It is very unnerving to hear the noise =))))))
If someone is interested in measuring of this DAС
lampucera.png ? Yandex.Disk
New Small DIY Gigawork Dac?Hide this!Advertise here!
DIY tube/phono pre in the same case as my DIY dac? ben62670 Analogue Source 3 29th October 2010 08:46 AM
Do you have a Gigawork DAC? Is this a mistake? ciagon Digital Source 4 8th March 2010 04:29 AM
Any experience with this ebay-dac-kit?(searching a diy-dac) xTr3Me Digital Line Level 2 31st December 2009 11:07 AM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
my very small DAC,24bit/192khz leesan Digital Source 0 8th May 2006 08:08 AM
