Hypex DSP module(s)
Hypex DSP module(s)
Old 11th January 2018, 11:41 AM   #1521
chris0712 is offline chris0712  Germany
Hello ds23man, I hoped that you will answer me, thanks. You mean that I must go direct from the analog output of the soundcart in the analog input of the Hypex, correct? I can not put a DAC with analog XLR out between?
Do you still have your ribbons?
Christoph
Old 11th January 2018, 02:43 PM   #1522
Hello,
I just tried with the onboard soundcard, but same problems. Do I need a extern soundcard?
I have also tried to import from holmimpulse a file as in post 1394 was explained, don't work, I could not see any file........
There is somehow the worm in it!
Christoph
Old 14th January 2018, 01:56 PM   #1523
The problem was the incompatibility between asio4all > soundcard > HFD.
I took a Tascam audio interface and it works now.
Old 21st January 2018, 09:13 PM   #1524
Windforce85 is offline Windforce85  Poland
I have a problem with DLCP. After installation in my loudspeakers and a few happy hours of listening suddenly it broke down.. I switched everything off yesterday evening and I went sleep. Today afternoon I switched in on again and... I suddenly heard loud buzzling screeching noise coming from one of Seas Excel channel! Membrane of this expensive driver in fraction of second was pushed out of the enclosure and than DC-protection in NCore module fortunately disconnected it right before any damage! But this was beginning of the problem. This failure is still present on CH2 outputs regardless of cabling, connectors, amplifiers used etc. This is with or without any input signal attached. It seems something is faulty inside of DLCP... What is more after disassembling, changing driver's assignment and putting it together again the same fault has occured on CH6 on the tweeter!!! I don't know if I didn't fried it up. I am affraid to swich it on again with any driver. DLCP normally operates in digital domain, it is recognizable in HFD, I can upload setting etc... Non-affected channels are playing (still) normally. Do you have an idea what it could be? How to check where is the problem? I have little access to any measurement gear...
Old 22nd January 2018, 06:11 AM   #1525
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Please contact Hypex.
Old 27th January 2018, 04:04 PM   #1526
TNT is offline TNT  Sweden
Where is the XTAL (oscillator) located on the DLCP? Cant seem to locate that component..
More distortion to the people!
Old 19th February 2018, 11:08 AM   #1527
Antana is offline Antana  Europe
Have you found it yet ;-)
Its right below the serial label. On the richt ride of the PCB. It is pretty large, you can not mis it...
Old 19th February 2018, 11:09 AM   #1528
Thanks - no, but I will now look again! :-)
Old Today, 12:24 AM   #1529
Doh - got it! Jepp it's that BIG!
Old Today, 02:14 AM   #1530
rfrauskolb is offline rfrauskolb
On July 17th 2017 I posted that I had developed a housing solution
for the Hypex DLCP and the power supply, which I offered to other members.
Nobody was ever interested in this offer.
Instead I am being asked, by receiving emails from the DIY site, to
help in the repair of malfunctioning units.
It is practically impossible to do this over the internet.
I am an electrical engineer and would be able to find the problem
with my test equipment in a relatively short time.
Some of these problems require the unit to be sent back to Hypex.
So, sorry to those seeking hardware malfunction solutions, that I
will not attempt to offer any solutions and engage in lengthy back and forth's.
FRANZ
Hypex DSP module(s)Hide this!Advertise here!
Low-cost active crossover module for Hypex UcD amps Al Garay Class D 2 2nd September 2014 08:36 PM
Low cost dsp based crossover module Crossoverman Multi-Way 38 20th February 2010 12:25 PM
Wanted Hypex Power Module rhcclark Swap Meet 2 18th July 2008 03:32 AM
DSP module with AD-DA Snickers-is Parts 4 20th August 2007 06:00 PM
Hypex UcD 400 AD amplifier module for sale mp006ltk Swap Meet 9 15th November 2006 03:56 PM
