| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all:
After reading about RC and LC filtering options, I'm not sure why major manufacturers use RC filters when dealing with multibit/sigma-delta DAC outputs. In theory, an RC filter is going to decrease the signal level and to introduce some thermal noise. In opposition, an LC filter doesn't lower the signal level and doesn't provide resistor thermal noise. I know that LC filters are difficult to build due to the required capacitor and inductor size but, once found a design getting both the required cutoff frequency and the possibility of comercially getting the parts, why using an RC filter instead an LC filter? Naming some practical examples, Marantz CD6000 builds a 2nd RC filter on the output of their two DACs (prior to using an active filter), and this morning I've got a Sony MiniDisc digital stage based on a CXD2564 multibit DAC building an eight-order RC filter on their outputs. The only problem I see from LC filters is te RF sensibility but, if properly shielded, shouln't it perform better than an RC filter when dealing with an unfiltered DAC output? Thanks. |
#2 |
1. RC filter doesn't reduce the level if it is used in an active design - OpAmp filter (with a good OpAmp). In a passive design, there are not so indicated. The Sony MiniDisc is not exactly an hi-end device, they didn't worry about S/N ratio too much.
2. Precision L components are much more expensive than an OpAmp. You want the filters to be identical on all your players, no? There are hard to use in SMD line. Individually shielding is multipling the costs by an order. Manufacturers cut costs by any means. Last edited by SoNic_real_one; 31st March 2010 at 10:43 AM. |
#3 |
Ups, I forgot it: yes, I'm talking about passive filtering.
So do you think is just a matter of costs? Seems convincent, as I said a passive LC filter seems, technically speaking, a better option than a passive RC filter. And expanding the thread to an active vs. passive filtering field, I'm trying to avoid active filtering for not depending on IC power supply implementations and IC specific tonal characteristics, ie, I want to use a passive filter approach in order to be as neutral as possible. Do you think I'm a crazy fool ?All your comments are welcome. |
#4 |
Only RC, LC has big "EMI fishing"
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua |
#5 |
An inductor that is useful at audio frequencies needs to around 10mH. Simple chokes on ferrite cores are very non-linear and have poor tolerance. You need an air gap to get linearity, which means many more turns on a big pot core and individual adjustment with a trimmer. This all adds up to expensive
Pot core chokes are very resistant to emi as the air gap is internal |
#6 | |
Anyway, by your comments seems that anti EMI measures MUST be had in mind if dealing with an LC filter. I was considering to fully shield all the LPF stage, do you think it should be enough to avoid problems or better going for pot core chokes? |
#7 |
Ok, at 350KHz you need values probably less than 1mH
5th order filters are sensitive to tolerance. You do not want left and right to be different |
#8 | |
#9 |
The magnetic fields inside are not zero. EMI is generated internally from the system clock and PCM stream traces on the PCB, some hum from the power transformer too. Just put a handheld AM radio near your board and hear the whistles and birdies. Also the L-C filters must not have any mutual coupling (mounted at right angles to each other) between L and R channels. I would shield the inductors.
#10 |
I have never been able to find a inductor that works for this. I've been told the only ones that sound good are air core speaker types, non of these are available shielded. Shielded these yourself is no easy task.
Best filter I ever used after a DAC was a tubes miller effect. |
| Output LC filter help | krish2487 | Power Supplies | 2 | 21st November 2009 12:25 AM |
| OK to run an RC filter on the output of my F3? | skaelin | Pass Labs | 2 | 16th October 2009 03:04 PM |
| Class D - LC output filter - C ripple current | Skeebopstop | Class D | 8 | 26th February 2009 05:08 AM |
| Voltage-out DAC without an output filter | mudihan | Digital Source | 4 | 18th September 2007 03:20 PM |
| LC and RC filter, trying to understand them | pjpoes | Power Supplies | 4 | 21st February 2007 07:44 PM |
| Page generated in 0.11879 seconds (80.43% PHP - 19.57% MySQL) with 10 queries |
