Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th May 2010, 02:02 PM   #11
The pot core types with air gap in the centre are fairly well self-shielded, certainly several orders better than a rod or "D" core types with an air gap exposed to the world
They can be mounted close to each other without cross talk
Old 8th May 2010, 08:25 AM   #12
regal is offline regal  United States
Where do you find them?,
There is a DAC I had called the Lite DAC-60 that uses a passive I/V then LCLC then SRPP. I made it a first order LC but could never find a inductor that sounded as good as the big air core speaker inductors, problem was it hummed with those air cores. I eventually got rid of the LC filter + SRPP altogether and replaced them with an anode follower with a cap from plate to grid to increase the miller effect enough to give a -3dB around 50khz, that was the best configuration after trying many different models of shielded inductors. The cap is multiplied by Mu for its filtering so it allows you to use a smaller high quality cap.
I guess what I am saying is for a i-out DAC LC filering is troublsome, not because of the design on paper but because "audio quality" shielded inductors are difficult to source. With a V-out DAC it may be more feasible because the signal is probably less likely to pick up interference.
Output LC filter help krish2487 Power Supplies 2 21st November 2009 12:25 AM
OK to run an RC filter on the output of my F3? skaelin Pass Labs 2 16th October 2009 03:04 PM
Class D - LC output filter - C ripple current Skeebopstop Class D 8 26th February 2009 05:08 AM
Voltage-out DAC without an output filter mudihan Digital Source 4 18th September 2007 03:20 PM
LC and RC filter, trying to understand them pjpoes Power Supplies 4 21st February 2007 07:44 PM
Page generated in 0.07627 seconds (73.49% PHP - 26.51% MySQL) with 10 queries
