Wolfson WM8741 Evaluation Board
Old 26th March 2010, 05:31 PM   #11
ChrisR1983 is offline ChrisR1983  United Kingdom
Building one for me sounds good :-)
how much would you charge?
Chris R
Old 26th March 2010, 05:31 PM   #12
Chris R
Old 26th March 2010, 06:38 PM   #13
paulb is offline paulb  Canada
Since you have two independent secondaries, you can build 2 positive power supplies and connect the outputs in series to give you a +/- supply (if you don't know what I mean, you should find a local acquaintance to help you wire it up). Two of the Maplin kit would work, as would
The σ25 Regulated Power Supply
Alternatively, this is a reasonable dual supply that can be used with a centre-tapped or dual secondary transformer:
ShinyMetal
Old 25th June 2011, 01:41 PM   #14
Centvrion is offline Centvrion  Italy
Centvrion's Avatar
Ehm...it's a bit late....but I suppose that a computer SMPS would be perfect at a reasonable price.
Just cut the molex plug, used to power HDs or CD players. This one has +12/0/0/-12V on it....so it would perfectly fit...
BUT the aim of my post is: how does this evalution board compare with other DACs or (for exemple) a Sound Blaster? How much I have to spend to get a better DAC?
Wolfson WM8741 Evaluation BoardHide this!Advertise here!
Wolfson WM8741 lduarte1973 Digital Line Level 33 18th December 2015 01:47 PM
WM8741 Eval Board ChrisR1983 Digital Line Level 7 9th October 2009 12:37 PM
Evaluation board as DAC? ctong Digital Source 4 2nd October 2007 10:31 PM
TA2024 evaluation board opentop Class D 10 12th April 2005 11:31 PM
