| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#91 |
Do You think that thermal and contact voltage noise of this trimmer will not be converted by comparator into phase noise(jitter -in time domain)?
In my opinion resistance of this trimming resistor is far too big and i prefer two constant walue resistors acting as attenuator . |
#92 | |
One Seriously Addicted to Audio and Electronics
As I use the oscillator without an output cap, since I have only a single supply available, there's about 2,5V offset present on the non-inv input. By applying the same offset to the inv. input the switching point of the comparator should move to the center of the wavform and make a 50% square wave. At least that's my idea, and it's the same as your's I think, only with a different explanation ![]() The 431 circuit uses feedback to regulate the output voltage. The divider is at the output side and provides a feedback to the 431. Any noise produced by the 431 will be present at the output because it's a closed loop, correct me if i'm wrong. The other circuit has the divider at the input side and doesn't use feedback. The voltage at the base of the BC550 is well filtered by the divider R1/R2 and C3. Nothing more than a passive RC filter. The transistor is a simple voltage follower that provides extra current. My guess is that this transistor produces less noise than a 431 + transistor combination. But of course it may sound worse, i'm hoping to find out ![]() Greetings, Ray. |
#93 | |
Banned
My goodness, Do you really thinks so? I am am using a Cermet Vishay trimmer. Earlier versions had no trimmer but sounded less good..... |
#94 | |
Ray. |
#95 | |
Won't the 100n cap take care of that? Two fixed resistors sounds good, at least it rules that part out. Ray. |
#96 |
I suggest to use low noise Vref rather than voltage divider directly from supply to adjusting duty cycle .
#97 | |
Banned
Schematic??
#98 | ||
#99 |
Hi bitrate,
Beautiful cat!!! |
#100 | |
How about using a LM317 with adjust pot to be able to trim the offset voltage? Does it have enough lf-rejection on it's adjust-pin? Thanks for the tip! Ray. |
| Problem with Elso clock | falter | Digital Source | 19 | 19th November 2006 02:53 PM |
| Elso Clock in CDT or DAC | patricklyw | Digital Source | 28 | 15th December 2003 10:25 PM |
| Elso clock KC-7 for Dac TDA1543 with CS8412 | bsyyu | Digital Source | 3 | 10th August 2003 06:28 PM |
| Page generated in 0.12847 seconds (82.38% PHP - 17.62% MySQL) with 11 queries |
