| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Sorry for my ignorance but as far as I can makeout this is not possible on this unit. I want to do some testing of my modified unit without doing any active crossover functions with just a single stereo amp. Is there a way to route to 2 ouputs? Thanks!
#2 |
Nobody ?
#3 |
Yes there is.
The Emerald Physics CS3 uses the DCX only for frequency and phase correction. Crossover is fully passive and internal to the speaker. I don't remember the menus as I don't have a unit, but you can patch the input straight to one pair of outputs. It's should be in the initial setup menu, where you set the 'stereo link' functions. |
#4 |
Just turn off the filters (crossovers) - that all you need. It's in the menu where you choose the filter type. Choose "off." In that way it is a simple pass thru. I've done that and inserted it into the tape monitor loop of an amp. Good way to test the basic functions.
You can turn on or off almost any function on the DCX.
Take the Speaker Voltage Test! |
#5 |
Thank you guys, works great! (Experimenting with Jan's active output, PSU + oettle mods
| Tent clock output voltage and DCX2496 | 2KW | Digital Line Level | 3 | 22nd October 2009 01:36 AM |
| active subwoofer and 2channel amp. | calvin14 | Parts | 4 | 16th July 2009 04:08 PM |
| Simple DCX2496 analog output boards | novec | Group Buys | 1 | 18th September 2007 05:32 PM |
| audiofonics 800w 2channel subwoofer amplifier | DXPLICIT | Car Audio | 2 | 27th August 2007 03:15 PM |
| FS: Behringer DCX2496 with digital output mod | Spiritzly | Swap Meet | 1 | 15th October 2006 02:08 AM |
| Page generated in 0.06960 seconds (73.43% PHP - 26.57% MySQL) with 10 queries |
