Go Back   Home > Forums > Source & Line > Digital Line Level
Old 5th February 2010, 05:36 AM   #11
nonsub is offline nonsub  Canada
Originally Posted by Bfpca View Post
Hi Folks
The only reason I can think of is that the voltage input will be higher using the 1:1.21 transformer. With .5v in you would have .605v out of the transformer. This may become an issue with sources that have low levels, I'm not sure. The input Z is set by the resistor and I believe the recievers are usually differential so I am not sure what the intent is. I notice that it seems to be common to use the 1.21 transformer so it may be more ideal with the input stage of the reciever , not sure. I am using spdif coax in through a DEQ 2496 and no problems. One other thing is that the DCX / DEQ have AES inputs and may be optimised to work with AES signal levels/ impedances. It would be interesting to look at the waveforms going into the receiver to see what it looks like.
Cheers
Brian
Hi Brian. I would think that the extra .105v isn't going to do squat as it doesn't even approach AES voltage spec? Since it works then the receiver must be able to take low level signals. Indeed from what I can make out the datasheet says -.3v to .8v for low in (I'm a newbie though and maybe not even reading the right thing, also if this is the case I don't even understand how it could be a negative v!) So at the end of the day there seems to be no point in the xfrmr?
Digital SPDIF-AES/EBU interconnect Nuuk Digital Source 3 11th April 2012 07:22 PM
Pulse transformers SPDIF/AES-EBU Kurt von Kubik Digital Line Level 14 14th November 2009 04:50 PM
AES/EBU to SPDIF coax input, how? tubenut Digital Source 48 16th February 2005 07:45 AM
SPDIF to AES/EBU Kari Digital Source 4 21st February 2004 11:29 PM
DIGI balanced AES/EBU -> SPDIF Coax meta Digital Source 3 26th May 2003 05:51 PM
Page generated in 0.06232 seconds (67.72% PHP - 32.28% MySQL) with 10 queries
