| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I was looking at some pics of modded equipment. One fellow seemed to like to put copper tape on top of all IC's, wire them to eachother (and assumedly tie to digital ground.) Is this know to actually do anything? Thanks!
#2 |
I´m amazed!
It may shield some RF emission or irridation.
#3 |
Or make it worse esp if not grounded really well. LOL
If you polish it up it looks real purty tho
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 |
I've done that on some RF equipment to improve stability,and 'clean up' some digital noise..It helps. One drawback with RF circuitry,is that it can change the stray capacitance,and de-tune things slightly,so you might need to compensate.
#5 | |
Besides applying RF bandaid's are just used for discovering the true cause of a bigger issue best solved by other means. I don't think anyone can say in their right mind, by globally sticking random pieces of foil atop IC's will be an improvement, sorry. EDIT>Thermally it would make it worse than just basic black plastic.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 30th January 2010 at 07:47 AM. |
#6 |
What about sticking blu-tacks?
#7 |
Do the tuning dots go under on on top of the copper then LMFAO
#8 |
#9 |
Is it to provide a heatsink. Grounded to dissipate any accumulated charge?
#10 |
It's to provide an electrostatic screen against all the clattering going on inside the IC. But to be effective, it needs a low inductance path to ground, and that means it needs to bond directly to a ground plane at each end of the IC.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Copper heatsink tweak - Thermaltake Copper Heatsinks | Ruach | Digital Source | 16 | 23rd September 2006 10:59 PM |
| IC's for 2.1CH O/P | bimbla | Chip Amps | 8 | 28th November 2005 10:54 PM |
| CS8412CP ic's | werkhoven | Digital Source | 10 | 14th February 2005 09:14 PM |
| Anybody knows where t oget cheapie self-adhesive copper tape?? | li_gangyi | Everything Else | 8 | 13th December 2003 04:57 AM |
| 3M Conductive Copper Foil EMI/RFI tape | KevinLee | Swap Meet | 0 | 25th May 2003 03:11 PM |
| Page generated in 0.09532 seconds (78.68% PHP - 21.32% MySQL) with 11 queries |
