Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd January 2010, 03:55 PM   #1
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Recommend a portable USB DAC?
When I'm travelling, I have a pair of Stax SRM-001 electrostatic in-ear headphones which I drive from the line output of my Sony D777 portable CD player. It sounds fairly reasonable, although the Stax sound much better from a proper source. However, the main bugbear is having to carry lots of CDs. It would be more convenient to play .wav files from my notebook - a 16GB USB stick could hold 20-30 CDs. But the onboard audio quality of a notebook is rubbish, so can anyone recommend a decent USB DAC that is ideally powered from the USB interface or its own battery? I don't need a headphone output or volume control, just line output.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 23rd January 2010, 03:58 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Like so: Pacific Valve & Electric Company Pacific Valve Musiland Monitor 01 US ?
jd
/Another new issue: Linear Audio Volume 3!
Old 23rd January 2010, 04:06 PM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
If you have a PCMCIA slot, have a look at Echo Digital Audio Corporation
It was recommended to me in this thread and the guy who bought is seems very pleased.
Old 23rd January 2010, 04:25 PM   #4
EC8010's Avatar
OK, so two possibilities I hadn't found in my trawls. The PCMCIA slot gadget looks ideal in terms of portability (but what does it sound like?), but even the Pacific Valve would be tolerable. I'll keep searching...
Old 23rd January 2010, 04:41 PM   #5
Netlist's Avatar
Hard to tell how it sounds, I’ve never compared it to anything else but :
The creators implemented 24/96 which indicates that they seemed to care about quality.
It must be pretty bug free, the guy that makes extensive use of it has no idea how PC’s work and he never ever called me to fix a non-working soundcard.
Old 23rd January 2010, 05:07 PM   #6
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
Putting 24/96 on an product is hardly a sign of quality. Any 30 euro/dollar DVD player has it on it, and even 5 euro/dollar PCI soundcards... I guess, this thing comming from Echo audio counts for a lot more
Even if it were a good product: PCMCIA is dying. You can't plug this in a normal PC (without extra hardware), and jamming lots of stuff in a very small package means that it will not be possible to use larger, often higher quality products. This does not mean that this is not a great product, but you should think about that.
Old 23rd January 2010, 05:16 PM   #7
Netlist's Avatar
They have smaller, too.
Note that I'm not affiliated in any way with echoaudio.
Old 23rd January 2010, 06:13 PM   #8
Netlist's Avatar
Please:
Old 23rd January 2010, 06:28 PM   #9
Hi!
I had a Echo Indigo I/O and I still own a Echo Indigo DJ pcmcia soundcard (the older ones, for pcmcia type II slot). For a really portable solution I think this is a very convincing card! The sound quality is really great for such a small piece of audio gear. Compared to an external high end dac it lacks a bit of naturalness and sweetness. But never the less the sound is fast, punchy, dynamic and precise over the whole frequency range, with great detail resolution.
If you buy the DJ version you get two analouge outputs, one variable and one fixed, suitable for headphones or for directly feeding an amp.
If you buy the I/O you get one variable output and one input for recording purposes.
The reliability is excellent, and the drivers are carefully programmed and updated frequently. It also supports asio natively!
Regards!
Martin
Old 23rd January 2010, 07:16 PM   #10
EC8010's Avatar
It looks as though the arguments about PCMCIA size and likely audio quality may be academic because the manual for my Advent 4211-B says the slot is a card reader, and doesn't mention PCMCIA. Looks like an external brick may be the answer.
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
Wanted: External, portable CD-ROM or DVD drive; decent USB DAC, portable speakers. Spasticteapot Swap Meet 0 31st May 2006 02:13 AM
Making USB powered gear, portable?? redrabbit Power Supplies 3 3rd April 2005 12:32 PM
Page generated in 0.10186 seconds (88.42% PHP - 11.58% MySQL) with 10 queries
