Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd January 2010, 07:42 PM   #11
Well, in this case you might consider the Super Pro 707 USB DAC.
Super Pro DAC707
You can read something about it's potential here:
So many DACs, which to choose
Old 23rd January 2010, 07:48 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I'm happy to use an external brick DAC, but it must have either its own battery or run off USB. External power is not allowed as this has to be portable (otherwise, I'd use my DACmagic). I had a look at the Musiland, but Pacific Valve have not quite worked out that there are other countries in the world other than the US of A and their ordering system can't cope.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th January 2010, 06:13 AM   #13
The usual suspects (so far as DIY goes) are:
AlienDAC (datasheet PCM2702 implementation - note that PCM2702 is becoming unobtanium fast)
BantamDAC (same as a above, but on a tiny board)
AMB Gamma-1 (PCM2707 for conversion to I2S, then a decent wolfson DAC)
GrubDAC (new design similar to bantamDAC, but using a wolfson DAC with a built-in voltage inverter which allows for a much simpler board and eliminates output coupling capacitors)
I use a Gamma-1 as my everyday DAC driving a Pimeta headphone amp, the combination is excellent. I also use a BantamDAC for connecting the laptop to the stereo - because the board is so tiny, it can be built as a "cable-dac" - a small box with a USB lead running in one side and RCA straight out the other. I've got a GrubDAC PCB on order, too, because one can never have too many USB DAC's, and I already had a few PCM2707 around.
If you'd like something which can drive headphones, look into the "Carrie" design over on Head-Fi, it's a version of the Mini3 adapted for USB power, with board dimensions designed to fit with a BantamDAC or GrubDAC in a Hammond 1455C80x case.
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
Wanted: External, portable CD-ROM or DVD drive; decent USB DAC, portable speakers. Spasticteapot Swap Meet 0 31st May 2006 02:13 AM
Making USB powered gear, portable?? redrabbit Power Supplies 3 3rd April 2005 12:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
