Behringer DCX2496 digital X-over - Page 363 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th January 2014, 04:16 PM   #3621
Pano is offline Pano  United States
Pano's Avatar
OK, that's a strange one....
I used to have some pop and drop issues when I was running 44.1K out of a laptop to the DCX. Found it was a grounding problem. Using a 75 ohm to 110 ohm transformer helped, as did better grounding. But I didn't relate that to the DCX, just to my bad wiring.
Simple fix - do you think it hurts to up-sample with your sound card? Since the DCX up-samples to 96/24 anyway. Do it in software, do it in the soundcard, do it in the DCX. Not sure which is best. That doesn't help you with the CD player, tho.
I wonder if a 75>100 ohm transformer would help?
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 18th January 2014, 10:28 AM   #3622
Viper_user's Avatar
I go for the 96 up-sample in the sound card. It works.
Unfortunately we don't have real grounded power in this house.
Old 18th January 2014, 01:01 PM   #3623
Originally Posted by AndrewT View Post
I think this confirms you have a "pin 1 Problem".
google it.
Build the hum detector that Whitlock/Rane suggests.
Pin 1 of all outputs and all inputs goes direct to Chassis at the in/out socket.
Never to the PCB, nor other grounds, inside the chassis.
I will check this! Thx
Old 19th January 2014, 07:19 PM   #3624
Groundloops's Avatar
Default Pilgham Audio SRC - Where to connect V+?
Took my dismantled DCX off the shelf after years. I once bought a Pilgham Audio SRC/Clock but mislayed the manual and so I wonder where to connect V+ ...
Can someone provide a picture or simply tell me what pin ist to be fed with V+?
THX!
Old 23rd January 2014, 09:42 PM   #3625
oettle is offline oettle  Germany
THX!
SRC/clock mod installation instructions
1. Disassemble R34 (22 ohm) on solder side of DSP board
3. Disassemble IC1 (CS8420) on component side of DSP board
Preferably with hot air or cut the pins carefully or lift the single pins with a needle and soldering iron
Avoid any forces on the PCB !
4. Assemble female 26-pin ERNI connector instead of IC1
a, "Straighten all pins of row B a little bit so that they touch the pads of CS8420
Flatten all pins of row A"
b, Solder row B: B1 = pin28 ... B13 = pin16
c, Bend (45) long side of pins close (~1mm) to the header and cut pins on long side of pin header
d, "Insert pin header: A1=pin1 . A10=pin10
underneath pins of SMD connector"
e, Insert wire: A3 = 9volt (IC7,pin1 or connectorX3,pin3)
Old 24th January 2014, 01:57 AM   #3626
Old 24th January 2014, 08:34 AM   #3627
Modifications for Behringer DCX-2496
1. ‘Dull sound’ problem (digital input)
I wonder if this was a near permanent failure in my DCX? Even though I used analogue input.
I could not get my active to sound as good as passive. That why I gave up that project.
Now I suppose I have to fit the "Oettle Mods" and steel my self up for trying again.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th February 2014, 08:08 AM   #3628
Default psu for dcx2496
hi everyone,
do any of you know where i can buy a new or used psu for a dcx2496?
cheers,
al
Old 27th March 2014, 12:25 AM   #3629
Deodato is offline Deodato  Netherlands
Originally Posted by oldtown View Post
hi everyone,
cheers,
al
The SMPS of my DCX broke down too - it turned out to be one of those bad elco cases. The 400V 47uF directly behind the (high voltage!) rectifier to be precise. It showed a slightly bulged top. After all it was an inexpensive and easy fix, I would say check that elco first.
Old 27th March 2014, 02:17 AM   #3630
I've wondered in the past if one could use a
Li Shin LSE9910A03 in a PINCH?
I agree, chances are the thing has something simple wrong.
I have many ideas how to improve the stock supply, but you need to fix it first.
File Type: pdf behringer_psu_dcx2496_deq2496_pwr_rev_d_sm.pdf (389.6 KB, 74 views)
Copyright 1999-2017 diyAudio
