Behringer DCX2496 digital X-over - Page 351 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 25th July 2013, 09:49 AM   #3501
Ste,
the low pass filters are correctly set up to achieve LR4.
The high pass have an error in that the 47k is not equal to 100k/2 This will change the Q of the filters
100k in many of the filters will give rise to avoidable noise.
You have 3 cascaded +6dB gain stages on all the outputs. This is an extra +18dB of gain. Do you need any of that extra gain? This will create avoidable noise.
You have no RF filtering on the input.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th July 2013, 02:30 PM   #3502
stewin is offline stewin  Kenya
hi andrew thanks for the reply. pls can you draw a schema or circle and replacement components in the schema with m.s. paint, with the correct values or if you are using eagle i have attached the .sch and the brd files
Old 26th July 2013, 12:09 PM   #3503
You have 100k & 47k in the high pass filters.
For a Q=sqrt(2) to give a Butterworth roll-off you should have 100k & 50k.
Cascading two Butterworth 2nd order filters is what gives you the LR4.
Compare to your low pass filters. You have single and double capacitors for that exact 1:2 ratio that is needed for the correct Q.
regards Andrew T.
Old 18th August 2013, 08:11 AM   #3504
Foxx510 is offline Foxx510  Australia
My dcx has started to do the digital input cs8420 notch filter bug every time I use it lately. The ribbon cable doesn't seem to be the cause, even though that was faulty and causing dropouts before i reseated it. As far as I can tell there isn't an easy fix for this bug, is there? It's about to go out the window and be replaced with a minidsp.
Old 18th August 2013, 08:42 AM   #3505
noSmoking's Avatar
well 2 ways,1 get a dac board off ebay and patch it in or 2 replace the chip,
I stood the board vertical and brushed the legs(pins) with a small torch ,the chip will fall off when it gets legs hot enough ,or cut the legs and pull them off one at a time ,A used motherboard is a good practice before the real deal,
works as it should now ,might also replace the caps around that area with oscons,Good luck!
NS
Old 18th August 2013, 09:56 AM   #3506
Cheers NS. I have an old Ebay DAC here that uses a CS8416. What's involved in patching that in to the dcx? Thanks heaps for the help :-)
Edit: similar to this? http://freerider.dyndns.org/anlage/i..._IMGP2541.html
Old 18th August 2013, 04:56 PM   #3507
if your unit does go south, PM me. I need a PS for my DEQ2496.
Samsung 60" LED, Outlaw 975 prepro, Samsung BDP, Charter DVR; Tri-amped(!) LR: Parasound 855 & 2 Rotel 980s ->Polk RTi A7 ; Tri-amped(!) CC: Rotel 985 ->Polk CSi A6; Mackie 1400->DVC 15 Sub; Surrounds: Hafler XL280->Polk RTi A3
Old 18th August 2013, 05:10 PM   #3508
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Hey,I got 1 or 2 PSUs....
Regards ke
Old 18th August 2013, 05:23 PM   #3509
Please PM me w/detail$ Tony
Old 18th August 2013, 08:04 PM   #3510
noSmoking's Avatar
Edit: similar to this? Neue Eingagsstufe fr DCX2496
I replaced the chip,but here's what I have for the add on CS board,
I did some serches and also yahoo groups got alot of info,Look up Linuxworks on this site.
here's a pic to wire it!
NS
Copyright 1999-2017 diyAudio
