Behringer DCX2496 digital X-over - Page 350 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 11th July 2013, 05:06 PM   #3491
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
I think I have one of those adapters somewhere. Seem to remember buying one years ago. But a USB model without adapter would be current/up-to-date.
Thx-RM
Old 11th July 2013, 05:53 PM   #3492
noSmoking's Avatar
Well I have been putting of doing a volume control mod,Should have did this long ago ,so much ezier to set up the balance on the 8 different channels on 2 dcx's,I did basicly whats been posted I used a 10K pot and I jumped the mute and used the pins on the op amps pins1 and 6,I put a 1K resistor inline and a .001 cap across a 47 uf cap,I used some better 47uf caps ,I think the ones I removed were as old as the unit and cheep,LOL. I think some oc-cons for the digital section and maybe some new power supply caps,
Has anyone that replaced the power supply with a linear one care to comment?
Clocks seem to be a big inprovement also,
Thanks,
NS
Old 11th July 2013, 07:04 PM   #3493
jan.didden's Avatar
DCX - Pwr.Supply
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 12th July 2013, 07:27 AM   #3494
noSmoking's Avatar
Default hi Jan,
Originally Posted by jan.didden View Post
Did the power supply help the sound,was it a big change to replace it?
Thanks,
NS
Old 12th July 2013, 07:43 AM   #3495
jan.didden's Avatar
Thanks,
NS
That's a hard one to ask the designer
It's not dramatic, but for me it did change for the better.
Just personal opinion.
BTW Pilgham Audio, the guys I send those link for, told me there was a fire in the server room of their provider and they are now trying to rebuild there site. I think the pictures aren't rebuild yet as of Friday morning.
If you want info probably best to mail them.
jan
Old 12th July 2013, 11:28 PM   #3496
noSmoking's Avatar
Default Thanks alot!
jan
Hi Jan ,
I'll check that site out ,I know you made it but you probably would have scrapped it if it wasn't better than stock,Looks like a new design Too!
Thanks alot,
NS
Old 13th July 2013, 07:25 AM   #3497
jan.didden's Avatar
Hi Jan ,
Thanks alot,
NS
Yeah the challenge was to manage space and heat dissipation for a linear regulator in that tight space.
At the end I selected an external wall-wart transformer (12VAC) that directly feeds the 5V, 3.3V and 6.2V regulators. A small, PCB-mounted custom 12VAC to 2 x 18VAC transformer drives the +/-15V regulators.
I even succeeded to re-use existing mounting holes in the box, so no drilling required!
jan
Old 16th July 2013, 07:58 AM   #3498
pedro11 is offline pedro11  United Kingdom
I have a duff Behringer dcx2496 could not find any one to repair it for so took the plunge & bought another used one with warranty OK . I want to go active with my Pheonix speaker . I have read many issues with it . You have got remember I am past my sell date so bear with me . The volume control I think is the main problem + others What do I really need to to overcome the issues please . I would need a lot info + help on this one .
Thanks Peter
Old 24th July 2013, 12:54 PM   #3499
stewin is offline stewin  Kenya
hi all . abit off topic i am new in this forum been invited by no smoking . here is my 4 way analogue active cross over . i have tested it, it works and it is impressive.
i have used linkwitz 24db way all 4 channels have high pass and low pass filters the frequency division is in the schematic pls share your comments and experiences .
have fun
Old 24th July 2013, 05:52 PM   #3500
noSmoking's Avatar
have fun
Hi Stewin,
Looks good , Could you post the silk or a stuffing guide?
Power supply is + - 12volts,what transformer did you use?
I will start them soon ! Thanks for posting!
Copyright 1999-2017 diyAudio
