Behringer DCX2496 digital X-over - Page 315 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th October 2011, 01:27 AM   #3141
Is it ok to copy some commentary on here, and to attach the pdf ??
Please post it here.
Old 11th October 2011, 12:30 AM   #3142
MurphyUHF10's Avatar
Hi 4pyros,
I have attached the pdf for the front panel deactivations..
There is quite a lot of good dialog on this topic in the yahoo users group, but in summary, this is the mod:
"..I choose to turn off/on in the same time both the LCD and the display LEDs, so I
used a double pole switch:
- One pole to invert RST on the display to RST from DSP or to GND. It deactivate
LEDs but not front panel buttons.
- Second pole to switch on/off backlight anode on the LCD
RST on LCD is still connected permanently to RST on DSP even if re-routed
through my new cables. So LCD is always active but dark!
Of course you can choose to have the LCD always on and use a single pole switch..."
Hope this helps!
DCX2496 Front Panel Deactivation.pdf
CM
Old 11th October 2011, 12:34 AM   #3143
Originally Posted by mhelin View Post
Quite a lot RF EMI there inside the DCX, maybe a new PCB design for the "mother board" would be needed:
Signal from DAC's to I/O card
Unless you can't EMI shield the mother board then the only viable option to get a clean environment for the analog circuits is to use an optical digital (TOS/ADAT-) link outside of the rack box to external DAC's, right?
Hmm, interesting.. Surprising, none of the DCX "big guns" have commented on this in all the mods mentioned?? Perhaps it's negligible??
Old 11th October 2011, 01:13 AM   #3144
linuxworks's Avatar
is there an equiv for the DEQ2496? that also needs 'visual muting'
My Photostream:http://www.flickr.com/photos/linux-works/
Old 11th October 2011, 06:56 PM   #3145
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Maybe the Hypex DLCP, if they finaly get time to work on it!
Regards Gerhard
Old 11th October 2011, 07:20 PM   #3146
autopoiesis's Avatar
Question front panel deactivations - photo anyone?
Originally Posted by MurphyUHF10 View Post
Hi 4pyros,
I looked at the pdf and (ahem) don't quite understand it - does anyone have a photo of a completed mod?
Dogs have masters; cats have staff
Old 12th October 2011, 10:35 AM   #3147
Don't think it's negligible, the RF will cause noise in opamps and required for EMI filtering and special layout (enough caps everywhere, close ground layer next to signal) to avoid emitting the RF noise. The DXC pcb is very bad design EMIwise. The guy who made these measurements is pro electronics designer and knows this stuff very well (actually he's happens to be also one of the guys behind the WinISD speaker box designer sw). I'd say 99% of all DIY digital stuff on this forum totally neglects EMI issues. One problem is that you need expensive measurement devices to measure RF upto 1 GHz.
Anyway, here are another two interesting plots on RF EMI nearfield measurements:
DCX off
DCX on
I think there are only two possible solutions, either redesign the PCB or build optical digital outputs for DCX. Well, some mods like new clock are good anyway (the less jitter the less noise there will be).
Electromagnetic interference - Wikipedia, the free encyclopedia
Old 12th October 2011, 11:15 AM   #3148
What about a simple metal cover/shield over the DSP board??
CM
Old 12th October 2011, 11:43 AM   #3149
Pano is offline Pano  United States
Pano's Avatar
The DAC and ADC chips sit right on that DSP board.
Old 12th October 2011, 05:04 PM   #3150
Yes, maybe you could build a new DAC board and put it into shielded case a little further from the DSP board. Like replace the analog board with a one properly designed digital+analog one, and a separate PSU of course. You could get the I2S signals quite easily from the DAC pins (the clock signals) and PCB nearby (from the three resistors next to DAC's). You might even use the same DAC chips as they are fine (if you can delsoder them, QuickChip makes good desoldering solder for that purpose).
Copyright 1999-2017 diyAudio
