Behringer DCX2496 digital X-over - Page 273 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 9th June 2010, 12:28 PM   #2721
oettle is offline oettle  Germany
I added a comparison list of the different power supply modifications to my Word-File (seel last page). Everybody who is interested in it may have a look at it. I hope there are no mistakes.
Old 9th June 2010, 02:25 PM   #2722
Davey is offline Davey  United States
Who's got a plot of this 10khz low-pass behavior? I'd like to see that.
Dave.
Old 9th June 2010, 03:23 PM   #2723
jan.didden's Avatar
Hi Frank,
A usefull chart, thanks for taking the trouble.
One comment: the 9V output for my regulator doesn't use an 7808 but uses a FET-regulator for a low-noise output of 8.7V nominal.
Also, the +/-15V regulators shown as 7815 and 7915 are actually brand-selected for low noise and high PSRR at higher frequencies.
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 11th June 2010, 07:23 AM   #2724
With a little help I created a list of all modifications for the DCX 2496 Iím aware of. Additional information, corrections and ideas are welcome.
Old 11th June 2010, 12:49 PM   #2725
doug20 is offline doug20  United States
Great stuff...but are all these docs with the same names different? so when I save them I have to rename each one or do they have the same info but additional pages each time?
For 2 years I have wanted to Mod my DCX but I just still do not think the changes are meaningful enough to spend > $500. I would rather switch over to Hypex AS100.2 amps/DSPs for about the same $$$.
Old 11th June 2010, 01:32 PM   #2726
jan.didden's Avatar
Originally Posted by doug20 View Post
[snip]For 2 years I have wanted to Mod my DCX but I just still do not think the changes are meaningful enough to spend > $500. I would rather switch over to Hypex AS100.2 amps/DSPs for about the same $$$.
... and then spend $500 to mod THAT one .
The nature of the (diy) beast, I guess.
jd
Old 11th June 2010, 01:36 PM   #2727
jan.didden's Avatar
Frank,
The CS3316 mentioned in my active board column should be CS3318. My bad.
jd
Old 11th June 2010, 01:47 PM   #2728
jd
I would find zero reason to mod it. The only reason I would mod the DCX is because of the gain structure issue.
Old 11th June 2010, 03:21 PM   #2729
Hi Jan, I corrected the CS3318. Thank you.
Hi doug20, the AS2.100 has a good price performance ratio. To be fair you would have to buy at least two of them to replace one DCX. I myself am using some higher grade Hypex amps and I am pretty happy with them. Nevertheless I still would prefer the DCX because my goal is not to spend a lot of time and to end up with something which is only above average because it has been 100-400 Euro cheaper.
Iím very concerned about the digital level control based on dither. Also the ADCs (100 dB) and DACs (104 dB) are only average. There is no information about jitter performance. And Iím with Jan if you would have a closer look at the design you most probably will find something which is worth being modified.
My conclusion is not only the AS2.100 has a good price performance ratio but also a modified DCX (~400-600 Euro). Everybody has to decide which quality level he wants to get and what he is willing to spend for it. Thatís life!
Old 11th June 2010, 03:45 PM   #2730
I’m very concerned about the digital level control based on dither. Also the ADCs (100 dB) and DACs (104 dB) are only average. There is no information about jitter performance. And I’m with Jan if you would have a closer look at the design you most probably will find something which is worth being modified.
My conclusion is not only the AS2.100 has a good price performance ratio but also a modified DCX (~400-600 Euro). Everybody has to decide which quality level he wants to get and what he is willing to spend for it. That’s life!
Yes, two of them costs $650 US shipped (Sorry, I love the Euro dropping like a rock! )....still cheaper then a DCX + Modding. MUCH Cheaper then a DCX+ Modding + AMP.
I already know the subjective nature of the SQ discussions...everyone has different content, listening levels, listening distances, room designs, etc. Its a moving target that should never have one conclusion.
Copyright ©1999-2017 diyAudio
