Go Back   Home > Forums > Source & Line > Digital Line Level
Old 5th February 2010, 01:22 PM   #2581
Pano is offline Pano  United States
Pano's Avatar
Legis, from what you say it would seem that the problem is in the analog input section.
If the auto-align and digital inputs work, that would point a finger at the analog input.
Have your tech check there first.
Take the Speaker Voltage Test!
Old 5th February 2010, 01:55 PM   #2582
Legis is online now Legis  Finland
Legis's Avatar
Originally Posted by pos View Post
Do you think it is due to the new dac or the new opamps? Did you also change some caps in that one?
I have no idea which one, I got them bot changed at the same time...
It's not that big, it's just bigger than before. Woofer jumps a little.
I'm thinking could the thump be too much fot a ribbon tweeter without a passive crossover? It is not loud but it consist of bass signal, because the woofer jumps a little. Could it harm the ribbon?
Panomaniac, I have them now workin' ok, just 1 hour ago installed them. The man said that some of the foils were torn of and that caused the B channel to go mute.
I ran RMAA just a minute ago, I think the improvement are pretty nonexistent with new DAC and op-amps, what comes to measurements. The dynamic range and noise floor has dropped approx 2dB's because of the slightly higher gain (RMAA's gain meter goes higher, very close to +/- 0dB, before it was something like -1,5 - 1,1 dB)
What comes to the character of the sound, the sound is very pure and clear. I have been running Zero DAC and Maverick Tube Magic D1 connected straight to the amps for this time the DCXs were gone. DCX does not hinder the sound in any way, compred to those DACs. Like I said before, when I took DCXs out of the signal path when I got them modded, I could tell a little imprevement in the sound after DCX were gone... So some, although quite small, purification has happened in the sound.
Old 5th February 2010, 02:19 PM   #2583
Pano's Avatar
Cool!
Old 5th February 2010, 02:44 PM   #2584
Legis's Avatar
Ops, I ment of course that noise floor has dropped and DR has risen, thus both have improved.
Old 5th February 2010, 05:07 PM   #2585
Legis's Avatar
Since this is a DCX related question and many DCX users face the same situation, I might as well as it on this thread.
Have you put any hi-pass filter for your tweeter while using active crossover like DCX? Which is the best way to make a passive crossover to tweeter/ribbon. A cap in the speaker cable rises the capasitance quite heavy if i want to use lower hi-pass like 1000hz.
Mainly I would like to have a hi-pass for ribbons, since their impedance drops near zero at low freqs. Thjis could burn both ribbons and amp.
Old 6th February 2010, 09:49 AM   #2586
I would prefer to see a cap protecting the tweeters from DC and excessive LF signal.
This passive filter can be adjusted to the required crossover frequency.
However it will not fall @ -6dB/octave due to the varying impedance presented by the driver.
Now you can add on an active filter to bring up the required filter pole and Q.
If you wanted Butterworth 4pole then a 3pole Q=1 active filter will add to the single pole Q=0.7 passive filter to give ~4pole Q=0.7 total filter, with an error in the 4pole characteristic due to driver impedance variation.
Now you need to look at the driver's acoustic roll off. This has to be added to the active and passive filters you have.
The result is not a 4pole Butterworth. It will take a quite a bit of time and expertise to achieve the target filter.
The DCX should make this process much easier to implement than soldering on alternative components.
Old 6th February 2010, 10:41 AM   #2587
Legis's Avatar
Is this a good choice for passive level controlling after DCX, competitor for seletronic cotroller jan Jan's system? Is has 8 channel control, which I would need since I have two DCXs each driving 4-way channel.
It's name is the SPL Volume 8. Looks quite nice.
Description: Sound Performance Lab
and heres a review in Germany: http://www.spl.info/fileadmin/user_u...at_volumes.pdf
Is there a cheaper 8ch controller around? It could be whole passive controller also, just eight potentiometers put in to a box without any transformer.
edit: would some Behringer's mixer work?
Old 6th February 2010, 11:03 AM   #2588
Legis's Avatar
Hi Andrew, I'm going to use that hi-pass filter only for ribboons' and amplifier's protection, the real hi-pass will be done with DCX. The passive hi-pass could be set to 1000hz and the real hi-pass to 3000Hz with DCX.
Because DCX thump when powering it up/-off, I think it would be wise to be safe than sorry with burn ribbons,m which are quite pricey (Fountek NeoCD3.0)
I'm not sure if i need any hi-pass filter I I could mod my DCX's starting regime so it would not thump at the power up/-off. Is there such a mod?
Theres still a possibilty that I might by mistake turn off the hi-pass filter of the ribbons.
Old 6th February 2010, 11:08 AM   #2589
Brett's Avatar
The power consumption is trivial. Leave the bugger ON all the time, so no thumps.
Old 6th February 2010, 11:09 AM   #2590
Legis's Avatar
Concerning the passive level control, this is very very interesting. XLR input and outputs, whole passive system, cheap.
One could add these as many as one needs.
TC ELECTRONIC LEVEL PILOT - Thomann Verkkokauppa
Is there possibly a better solution than this? I half-ready to order them
Information on manufacturer's website: http://www.tcelectronic.com/LevelPilot.asp
Edit: Here's another one, but not quite as good looking as TC electronics and does not have XLR outputs but instead jack outputs: http://www.thomann.de/fi/sm_pro_audio_nano_patch.htm
Page generated in 0.15156 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
