Behringer DCX2496 digital X-over - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd June 2003, 08:44 PM   #11
RobM is offline RobM  United States
Send a message via AIM to RobM
I'd probably just do some capacitor mods. Digital-outs would be cool, too...
Old 3rd June 2003, 10:06 PM   #12
diyAudio Moderator Emeritus
jean-paul's Avatar
Change the 4580's for something better.
It's only audio. Member of the non modular PCB design committee
Old 3rd June 2003, 10:18 PM   #13
Ricren's Avatar
Default Simulations and comparations
Hi byteboy,
One of my units is for the fronts.I have a couple of Urei 809 that are very difficult to work with, because they are coaxial drivers and the voice coil of the mid unit is firing behind the woofer, so you have to delay the woofer. This behringer unit seems to be the tiket.
The other is going to manage the rest of the 5.1 setup.
Let's see how it actually SOUNDS. I was doing some simulations in a ProTools system with different filter plug ins and delays and arrived at a nice setup in the digital domain. The problem is that this system is used to edit audio and is noot going to be used as a 20K digital crosover!
So when the behringer unit arrives I'll be able to test the sound between it and this efiting state of the art machine and see which one wins.
Ric
Old 4th June 2003, 01:23 AM   #14
Remy is offline Remy  Belgium
Thanks for the picture byteboy
Rémy
Old 4th June 2003, 01:28 PM   #15
byteboy is offline byteboy  Netherlands
Default DCX2496 / Urei 809
Hi Ric,
Seems to be the machine you need for your setup.
I am not familliar with the Urei 809 but it seems to be an interesting speaker.
I had a look at the delaysection as well.
I plan to use it to compensate the difference in distance due to the mechanical mounting of the tweets and mids in the two-way satelites.
And also between the satelites and the (sub-)woofer, which will be in a seperate closed cabinet.
I plan to use the equalizer section of the DCX2496 to compensate the power rolloff below 80 - 100 Hz of the woofer.
If you get your DCX2496, please keep us posted on how it performs in your setup; I will not be able to test/post results untill I have finished my cabinets.......
Henry.
Old 4th June 2003, 01:51 PM   #16
Default Changing 4580
Hi Jean-Paul,
(Nice avitar btw. Is it realy you or are you a big fan of Herman?)
What better (pin compatible?) opamp do you have in mind?
What would be the net benefit of this mod?
Mods on SMD boards in general:
I don't know about you guy's, but I have very bad experience with doing a clean mod on SMD boards without the proper special tools.
Henry.
Old 4th June 2003, 06:14 PM   #17
jean-paul's Avatar
Hello Henry, although I like Herman Brood I am not a real fan. The nice avatar was given to me by another forum member ( Ststone ).
I would have to see the schematic first but I think AD8620 is a good replacement. Otherwise OPA2604AU ( SO 8 ).
Just cut the pins and then desolder them with desolder-braid.
Old 4th June 2003, 07:21 PM   #18
Cheap SMD tweezers can also be had (I've seen them for under US$50 w/o temperature regulation) if you're going to do more than a little SMD rework.
Old 4th June 2003, 10:26 PM   #19
Default Re: More pics of Behringer DCX2496 digital X-over
Originally posted by byteboy
I think there is not realy so much to "see" inside.
Productin quality is good.
OpAmps are 4580 and ADC and DAQ are from AKM like stated in the documentation.
Are you still interested in mods Petter / RobM ?
Could you elaborate on what and how you would modify:
Are there better DAC's and ADC's which are (software- and pin-)compatible?
Costs?
Is it worth it?
Well, the way I see it, the pictures were worth a thousand words to me. I see a couple of avenues for modding:
Phase 00: Add a ferrite bead on power cord.
Phase 0: Evaluate whether power supply needs to be taken out of unit. Evaluate whether some bypassing near PSU improves sound. Add capacitance anyway (but use high quality stuff), and add an input filter (use a high performance low current unit). Consider adding common mode AND differential mode inductance on secondary.
Phase 1: Replace op-amps + analog filter components. Replace or enhance bypass caps near op-amps, and near DAC chips (both digital and analog).
Phase 2: Replace audio crystal
Phase 3: Replace DAC chips
Phase 4: Consider whether you can clock transport from the Behringer .....
Phase 5: Consider rerouting the wiring to the output
Phase 6..299: Go ask Thorsten (I disagree with some of his stuff, but am very impressed and it often strikes me: How did he think of that -- it is great!)
Petter
Old 5th June 2003, 08:50 AM   #20
Andypairo's Avatar
At what price did you get it?
Cheers
Andrea
Copyright ©1999-2017 diyAudio
