Behringer DCX2496 digital X-over
Old 8th December 2017, 12:36 PM   #4171
Pano is offline Pano  United States
Pano's Avatar
Have fun with the pot - is that legal? Let us know how well it works. You'll end up having 2 volume controls on the outputs, right? The 6-gang, then the volume on the amps themselves.
Take the Speaker Voltage Test!
Old 8th December 2017, 12:45 PM   #4172
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I'll be using 4 gangs for the time being with my WAW set up. I'm planning to use just one volume control but may have to attenuate further, what do you suggest?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 8th December 2017, 02:33 PM   #4173
bentoronto is online now bentoronto  Canada
Originally Posted by scottjoplin View Post
Details of the 6 volume chip here HTTP 301 This page has been moved
Thanks for link to chip data sheet. Not a word about distortion.
But I am curious about the how well these devices pan out when implemented. Seems there are a whole bunch of similar (identical?) devices out there.
F9 PGS2311 5.1 channel volume control kit+LCD Display+remote-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Can anybody offer some further guidance on buying an electronic ganged 6-channel volume control?
I couldn't be much happier than with my SPDIF coax to Input A and a multi-gang pot output control.
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and working on a folded 18-foot Voigt pipe)
Old 8th December 2017, 02:54 PM   #4174
Pano's Avatar
You'd want your amps to have their overall gain set fairly low, I would think. That gives you a better range on the 4-6 gang pot. Have you read the article on gain structure? It could help you understand how to set up things.
Old 8th December 2017, 03:13 PM   #4175
Yes, I'm aware of gain structure, I don't use a preamp. I'm probably going to need to connect individual pots after the ganged pots on the amp inputs, is there a prefered way to do this? The ganged pot is 10k log, would similar value afterwards be ok, the amp's input impedance is 22k?
Old 12th January 2018, 11:29 AM   #4176
I'm using S/PDIF as input, not having any problems that I'm aware of, quite long runs of any old coax to hand. If there was an issue with level would it be easily apparent?
Old 15th February 2018, 03:49 PM   #4177
When using the SUM function to make my stereo subs mono, I'm having to attenuate them both, does that sound right, ie even though it's doing it digitally they are still mixing in an analogue way if you see what I mean?
Old 15th February 2018, 03:56 PM   #4178
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
It is just the sum, like analog if you want.
I found you got to boost the sum if I remember correctly.
I think it was like 6dB.
Old 15th February 2018, 04:02 PM   #4179
I'm still using two outputs to two subs, so they are both getting the sum of left and right
Old 15th February 2018, 08:12 PM   #4180
If you set the DCX up that way, it should do it.
Behringer DCX2496 digital X-overHide this!Advertise here!
